rob_sri Posted September 15, 2013 Share Posted September 15, 2013 (edited) I've been doing some research into NA-T recently and there is ALOT of completely different set ups.. thought it would be a good idea to collect everyones NA-T specs in one place so we can see the effects of running different set ups and its reliability + performance, and also who has pushed the boundaries of what the GE can handle! If this has already been done and i've missed it then if you're a mod feel free to delete this thread What I'm proposing is you post the following information: 1 or 2 pictures followed by these headers Internal engine Mods (inc head work, cams etc): Compression Mods: Turbo Choice: Wastegate: intake manifold: Induction: Exhaust (size + make) inc manifold: Cooling mods: engine management: Boost control: Injectors and fueling: Ignition, plugs etc: any other electrical supporting mods: mapped by: gearbox, clutch and drivetrain: Power: Torque: Boost pressure: Date converted: Problems during build (or least favourite part ): any running issues encountered: any RR printouts to support! feel free to add any other headers for useful info that I may have missed along the way. Edited November 17, 2014 by rob_sri (see edit history) Link to comment Share on other sites More sharing options...
rob_sri Posted September 15, 2013 Author Share Posted September 15, 2013 not sure if this would be best posted here or in supra chat.. mods feel free to move if appropriate Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 15, 2013 Share Posted September 15, 2013 ill throw a few of the different ones ive done out there Internal engine Mods (inc head work, cams etc): oem Compression Mods: none Turbo Choice: t61 Wastegate: xs power intake manifold: oem Induction: mesh Exhaust (size + make) inc manifold: xs mani, 3" straight through Cooling mods: fmic engine management: emanage blue Injectors: oem Ignition mods: 4 runner dizzy 6d.btc any other electrical supporting mods: none mapped by: ryan g boost; 8psi gearbox: w58 Power: 385bhp Torque: 350lbs Boost pressure: Date converted: Problems during build (or least favourite part ): any running issues encountered: broke w58 any RR printouts to support! in one of my old threads somewhere clutch eaton 6 puk feel free to add any other headers for useful info that I may have missed along the way. clutch used Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 15, 2013 Share Posted September 15, 2013 Internal engine Mods (inc head work, cams etc): oem Compression Mods: tt pistons. oem head gasket Turbo Choice: t61 Wastegate: prescision intake manifold: oem Induction: mesh Exhaust (size + make) inc manifold:xs power , 3" toyo sport Cooling mods: fmic engine management: e manage blue Injectors: denso 550. twin oem pumps Ignition mods: 4 runner dizzy 6 deg btdc any other electrical supporting mods: mapped by: ryan g gearbox: w58 / r 154 Power: 490bhp Torque:450 lbs Boost pressure: 15psi Date converted: Problems during build (or least favourite part ): any running issues encountered: comprehensivly destroyed a w58 , fitted r154 any RR printouts to support! somehwhere f Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 15, 2013 Share Posted September 15, 2013 Internal engine Mods (inc head work, cams etc): oem Compression Mods: tt pistons , oem gasket Turbo Choice: t61 Wastegate: prescision intake manifold: oem Induction: mesh Exhaust (size + make) inc manifold: xs manifold 3" toyosport Cooling mods: oem tt smic engine management: emanage blue Injectors: denso 550cc twin wlabro 225s (buuzzzzz) Ignition mods: any other electrical supporting mods: mapped by: htp gearbox: david p hybrid auto Power: 510 bhp @ 4600rpm then wheels kept spinning. the tuning shop estimated 560+ by the graph but hard to tell Torque: 490 lbs up to the spinning Boost pressure: 20 psi Date converted: Problems during build (or least favourite part ): any running issues encountered: none any RR printouts to support! in an old build thread Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 15, 2013 Share Posted September 15, 2013 Internal engine Mods (inc head work, cams etc): oem Compression Mods: none Turbo Choice: garret gt4088 too big for this low boost build , very laggy Wastegate: xs power intake manifold: oem Induction: mesh Exhaust (size + make) inc manifold: xs mani, 3" straight through Cooling mods: fmic engine management: emanage blue Injectors: oem Ignition mods: 4 runner dizzy 6d.btc any other electrical supporting mods: none mapped by: ryan g boost; 8psi gearbox: w58 Power: 380bhp Torque: 340lbs Boost pressure: 8psi Date converted: Problems during build (or least favourite part ): any running issues encountered: garret oil seals failed replaced latter with t61 any RR printouts to support! in one of my old threads somewhere clutch eaton 6 puk Link to comment Share on other sites More sharing options...
rob_sri Posted September 16, 2013 Author Share Posted September 16, 2013 Very useful mate thanks..! Sounds like some good builds..! T61 seems to be a good choice Some nice W58 destroying going on there too haha..! How long did it last both times at that power :o? Link to comment Share on other sites More sharing options...
ballsdeep Posted September 16, 2013 Share Posted September 16, 2013 (edited) Internal engine Mods (inc head work, cams etc): OEM Compression Mods: OEM Turbo Choice: T61 Wastegate: HKS COPY 50mm 7psi spring BOV: HKS intake manifold: OEM Induction: 4" K&N Exhaust (size + make) inc manifold: 4" DP AND MP WITH FLEXI SECTION, XS POWER MANIFOLD TITANIUM HEAT WRAPPED Cooling mods: 600x300x76 FMIC eBay (toyosport) engine management: E-MANAGE ULTIMATE 3BAR MAP SENSOR Injectors: OEM 330cc but recently purchased mk3 440cc walbro 255 fuel pump Ignition mods: 4runner dizzy cap any other electrical supporting mods: AEM TRU BOOST GAUGE/CONTROLLER AEM AFR GAUGE, DEPO OIL TEMP + PRESSURE GAUGES mapped by: TUNING DEVELOPMENT http://www.tuningdevelopments.co.uk/ gearbox: W58 clutch: SPEC STAGE 3 fidanza lightweight flywheel Power: 260 hoping for near 370 this time! Torque: Boost pressure: Date converted: Problems during build (or least favourite part ): forgot to tighten intercooler pipe before I had it mapped resulting in boost problems, removed wastegate to pressure test to find it had the wrong spring installed! any running issues encountered: N/A Edited September 16, 2013 by ballsdeep (see edit history) Link to comment Share on other sites More sharing options...
rob_sri Posted September 24, 2013 Author Share Posted September 24, 2013 Looks good mate keep us updated with what it makes when you have it sorted..! Link to comment Share on other sites More sharing options...
monkey76364 Posted September 24, 2013 Share Posted September 24, 2013 Mine is going to Paul at Whifbitz tomorrow. Using his new NA-t kit plus ordered in a boost logic auto box and other parts, will be changing for TT pistons and other parts. The aim is 500-550bhp for the build. Once I get more details on all parts we decide, plus pics and dyno graphs I can update Link to comment Share on other sites More sharing options...
Rich.2211 Posted September 25, 2013 Share Posted September 25, 2013 (edited) Sorry to be lazy mate but I'm going to copy mine over from a document I saved on my computer if that's okay? If not I'll reconfig it under your headings. Engine: 2JZGE 2997cc XS Power T61 Turbo XS Power tubular manifold wrapped in Thermotec heat wrap 3” Downpipe wrapped in Thermotec heat wrap 3” Decat pipe wrapped in Thermotec heat wrap and straight through TRD style exhaust system 1.3mm 2JZGTE head gasket Head stripped and reassembled with new stem seals and lapped valves 650CC Siemens DEKA injectors with custom pigtails and shimmed fuel rail 4” Intake pipework 4” K&N air filter 3” Core Toyosports intercooler 2.5” & 3” Custom intercooler pipework 38mm Tial style wastegate with 7.5psi spring Toyota 4 Runner distributor cap with additional no.2 HT lead Open screamer pipe wrapped in Thermotec heat wrap AN10 Braided oil return with billet AN10 flange Braided oil feed hose with 3mm oil restrictor Blue anodized oil filter sandwich plate with 1/8th NPT threads Modified oil pan with billet AN10 flange fitted for oil return Air condition delete Power steering “up” system delete ACIS (acoustically controller induction system) and butterfly removed Shortened auxiliary belt T4 turbo blanket Custom painted red engine block Custom painted silver engine covers, engine mounts, ancillaries and inlet manifold Fuchs Titan Race Pro S 10W50 engine oil Toyota red coolant Walbro 255 fuel pump with fuel resistant heat shrink on all soldered connections Fuel pump ECU bypass for consistent 12V oppose to stock 9/12V switching Fuel damper delete with braided hose and AN fittings Single O2 sensor conversion Emanage Ultimate piggy back ECU mapped on Shell V Power 112MPH Speed cut removed 3 BAR MAP sensor Drivetrain: W58 five speed manual transmission Competition Clutch Stage 5 AO1B Torsen LSD Motul Gear 300 75W90gear box oil Motul shockproof 90W differential oil Mapped by: Lyndon (mkivsupra.net member) Power, Torque and Boost Pressure: 7.5psi, power figures unknown at present. Boost will be upped to 1 bar soon. Date completed: 31st August 2013 Problems during build (or least favourite part): Exhaust manifold stud thread was stripped inside the head so had to V Coil the head to fit a new stud and the oil return line is awkward to fit under the turbo. Lastly, one I don't see mentioned much, the oil return flange I used sat quite proud of the side of the oil pan meaning it caught on a thread for the power steering rack. Any issues encountered were all easily sorted Running issues encountered: Scares young children and old people Edited September 25, 2013 by Rich.2211 (see edit history) Link to comment Share on other sites More sharing options...
girth45 Posted September 25, 2013 Share Posted September 25, 2013 Looking good rich. Link to comment Share on other sites More sharing options...
Fly Posted September 26, 2013 Share Posted September 26, 2013 (edited) 2jzge 100 000 5-30w fully synthetic oil Internal engine Mods (inc head work, cams etc): ARP head bolts + serviced IAW TSM Compression Mods: tt headgasket 1.2mm Turbo Choice: t61 oil feed from Lexus Union bolt and braided line using 3mm oil restrictor. Oil return tapped in top of sump casting, different to usual but works fine, line covered in fire proof sleeve. Wastegate: xs power 50mm- modified screamer pipe covered in thermo wrapp. 3inch downpipe covered in thermo wrapp intake manifold: oem painted black Induction: K+N with cold air tube routed to filter Exhaust : Nurspec R cat back, 3 inch Cooling mods: fmic, 10 Row oil cooler from sandwich plate, AEM water meth, pre TB 630lph jet 50/50 mix engine management: emanage Ult + 3bar map sensor + O2 sensors replaced with simulated narrowband from wbo2. Injectors: 7mGTE 440s + 6ohm resistors Fueling - Aeromotive FPR , 4 BAR fuel pressure, Walbro 255 fuel pump, 12V mod, fuel pulsation removed. Ignition mods: 4 runner dizzy, new rotor arm, new leads other electrical supporting mods: mtxl WB02 gauge and data log, Greddy profec b boost controller , A working electrical drivers seat, oil temp gauge - sensor in sump. Boost gauge. AEM boost safe connected to power supply of boost controller allowing system turn off if water meth shows a fault, backs to 7psi spring pressure. Water on LED. mapped by: Dynotune ripley (they were shit) may as well have mapped myself, actually I did! Austec racing (great guys but issues with fueling) boost; mapped on road to 12 psi AFRs at 10.5 gearbox: V161 with CC stage four six puck clutch + lightweight flywheel + ARP flywheel bolts Other standard SZR parts such as Torsten diff, bilstein suspension etc. Intake/cam covers/ pipework colour coded in black/white. Lightweight power steering/ alternator/ aircon pulleys - stock crank pulley Power: ? Torque: ? Boost pressure:12psi Date converted: still ongoing Problems during build (or least favourite part ): lean running, a wiered flutter noise from turbo/exhaust cam, having a tiny garage, removing the sump without engine or sub frame being removed, gearbox removal, head replacement. Stripped head bolt. *update* flutter appears to be from a gap between turbo and manifold. The gearbox removal was an utter pita, have a friend help and get a head bearing removal tool. Removal of the head is probably easier with the engine out otherwise to get some of the lower runner bolts requires removal of the starter motor. Found a stripped head bolt as I was removing the head, requires drilling out and removal of all swarf. any running issues encountered: Running lean due to injector resistors being wrong( now fixed), Variable fuel pressue - tube from pump to hanger split and was leaking. any RR printouts to support! one at 250BHP at Dyno tune running 5 cylinders but mega lean. feel free to add any other headers for useful info that I may have missed along the way. Edited January 5, 2014 by Fly (see edit history) Link to comment Share on other sites More sharing options...
Fly Posted September 27, 2013 Share Posted September 27, 2013 Rich I just noticed you don't have the mahoosive crash bar on the front of your car, did you remove it? Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 27, 2013 Share Posted September 27, 2013 got 2 na-ts to do in the next too months with differing setups, ill update how they go - - - Updated - - - got 2 na-ts to do in the next too months with differing setups, ill update how they go Link to comment Share on other sites More sharing options...
rob_sri Posted September 28, 2013 Author Share Posted September 28, 2013 Awesome responses guys keep us updated with progress and importantly figures Videos are always a bonus too Rich that's fine mate my headings were just as a guide! Link to comment Share on other sites More sharing options...
rob_sri Posted September 28, 2013 Author Share Posted September 28, 2013 got 2 na-ts to do in the next too months with differing setups, ill update how they go - - - Updated - - - got 2 na-ts to do in the next too months with differing setups, ill update how they go Awesome!! Keep us updated! Good luck! Link to comment Share on other sites More sharing options...
Rich.2211 Posted September 28, 2013 Share Posted September 28, 2013 (edited) Rich I just noticed you don't have the mahoosive crash bar on the front of your car, did you remove it? Yes mate I removed it, the intercooler sits quite far forward and I want to make some proper ducting up for it and the crash bar was in the way. Edit - Just an update to this post.. I've now bought a new crash bar and bumper foam as I wasn't happy without it and it made the front bumper sag. Edited November 1, 2013 by Rich.2211 (see edit history) Link to comment Share on other sites More sharing options...
rob_sri Posted November 1, 2013 Author Share Posted November 1, 2013 anymore NA-Ts wish to post their specs ? Link to comment Share on other sites More sharing options...
bluedrag Posted November 2, 2013 Share Posted November 2, 2013 Internal engine Mods (inc head work, cams etc): OEM Compression Mods: OEM Turbo Choice: AR.70 Wastegate: HKS COPY 38mm 7psi spring (may be changing to hks 50mm) BOV: SSQ Copy intake manifold: OEM Induction: 4" K&N Exhaust (size + make) inc manifold: XS Power Manifold + 3" full custom stainless engine management: Link G4 Plug-in ecu 3 Bar map sensor Injectors: OEM currently changing to 550cc Denso's before i got for next map Ignition mods: 4runner dizzy cap any other electrical supporting mods: Boost Guage, AFM guage, Oil pressure guage mapped by: Initial tune done by Infomotive, (New Zealand) gearbox: W58 clutch: CI Heavy Duty Power: 250kw ATW (350ish HP at 14 psi) Torque: Acording to Dyno Sheet like 900nm but i think thats wrong Boost pressure:14 psi (over boosting currently i think WG is broken ) Date converted:Ongoing Problems during build (or least favourite part ): Kit didnt all fit together nicely most things needed small modifications to fit, wastegate not working properly any running issues encountered: Over Boosting Currently, link imposed 4600rpm limiter so as not to damage internals, ongoing issues with this Link to comment Share on other sites More sharing options...
rob_sri Posted January 4, 2014 Author Share Posted January 4, 2014 Any more ? Link to comment Share on other sites More sharing options...
buster Posted January 4, 2014 Share Posted January 4, 2014 (edited) Thought this would be a good way too keep progress of what I'm doing to the car and also a good way to show people I'm going for between 500-600bhp have to see what it dyno on the day My specs/parts... Low mileage n/a engine 60000 97facelift Billet fuel rail sard Battery to boot Billet water pump pulley cover Stainless steel bolt set for various engine bits Fuel pressure regulator Bradded fuel lines 5mm pipe for bov/wastegate/boost controller 5m plus Tee pieces x3 for 5 mm boost hose Willbro 255l fuel pump Turbo blanket alloy rad Oil sandwich plate 3" Turbo inlet pipe Spark plugs x6 Opieoils engine, diff, gearbox oil, and filters ARP Head studs Greedy E-manage ultimate 3bar map sensor 4 runner dizzy cap N/A gasket set TT head gasket 60mm wastegate hks rep Aem air/fuel gauge wideband o2 sensor Aem egt gauge injectors 650cc 2jz ge manifold with t4 flange hks ssqv bov depo boost gauge with volt meter oil temp and oil press blitz dual boost control all fmic pipes work 3" fmic 3" blitz air filter Polished T61 turbo Bradded Turbo oil lines Single turbo down pipe Second decat pipe 3" inlet pipe for turbo 3-4 reducer for turbo inlet 3" v band clamp for down pipe Piping for screamer pipe Twin electric fan kit 16row oil cooler and pipes TT inlet manifold in black TT cam covers with 10an breather fittings sprayed same colour as car TT Black spark plug cover Magnecor 8mm ht leads Stainless steel fmic cover plate Cnc machined rad brackets Trd oil cap 2 inlet catch can TT idle control valve TT throttle position sensor TT throttle cable Polished aux pulleys all hoses and an fittings Drive gear ............................... r154 gearbox brand new r154 stage 3 clutch brand new r154 flywheel brand new r154 slave r154 front of prop shaft chaser speedo sensor modified shifter housing r154 gearbox mount LSD and any other bits needed Various nuts and bolts Engine just before it went in the car Progress pics Edited January 4, 2014 by buster (see edit history) Link to comment Share on other sites More sharing options...
Dazzi Posted January 4, 2014 Share Posted January 4, 2014 Intrigued on how well the emanage coped with larger injectors. I thought it didn't control them too well. Link to comment Share on other sites More sharing options...
berg Posted January 4, 2014 Share Posted January 4, 2014 (edited) Engine 3000cc Straight 6 2JZ-GE T61 Turbo T4 Titanium Turbo Blanket HKS 50mm external wastegate & screamer pipe XS power turbo manifold 3" v-band downpipe TRD replica 3" exhaust Whifbitz 3" 2nd decat Oil filter sandwich plate Whifbitz oil feed and oil drain lines 440cc injectors (with resister pack) Wolbro 255 fuel pump TT 1.3mm headgasket (lowered compression) Large 3" FMIC 3" Intercooler pipework HKS SSQV BOV 4" intake pipe 4" K&N Filter BKR7E plugs Toyota 4 Runner dizzy cap No2 lead to replace no1 lead Drivetrain W58 5spd manual SPEC stage 3 clutch kit A01B LSD Suspension, Wheels, Tyres & Brakes Stock Bilsteins Jspec Brakes 18" Bronze Rota GRID Drift (8.5J fronts & 10J rears) Pirelli P Zero ROSSO (235/40/18 front, 275/35/18 rear) Electronics GReddy 3 bar map sensor GReddy E-manage Ultimate Piggy Back ECU GReddy temperature sensor AEM Wideband gauge AEM Tru Boost controller AEM oil temp gauge 60mm oil pressure gauge Thor shows 427hp 370 lbs/ft @ 14.5psi DynoDaze shows 393hp 360lbs/ft @ 10psi Will be back to dynodaze for a run on full boost to compare all Edited January 4, 2014 by berg (see edit history) Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 4, 2014 Share Posted January 4, 2014 Intrigued on how well the emanage coped with larger injectors. I thought it didn't control them too well. Not sure about Blue but my Emanage Ultimate controls my 650cc Siemens DEKA injectors perfectly. Starts, cold starts, idling etc. just as it did when it was NA Link to comment Share on other sites More sharing options...
