NA-T Spec Thread.
rob_sri
I've been doing some research into NA-T recently and there is ALOT of completely different set ups..
thought it would be a good idea to collect everyones NA-T specs in one place so we can see the effects of running different set ups and its reliability + performance, and also who has pushed the boundaries of what the GE can handle!
If this has already been done and i've missed it then if you're a mod feel free to delete this thread :)
What I'm proposing is you post the following information:
1 or 2 pictures followed by these headers
Internal engine Mods (inc head work, cams etc):
Compression Mods:
Turbo Choice:
Wastegate:
intake manifold:
Induction:
Exhaust (size + make) inc manifold:
Cooling mods:
engine management:
Boost control:
Injectors and fueling:
Ignition, plugs etc:
any other electrical supporting mods:
mapped by:
gearbox, clutch and drivetrain:
Power:
Torque:
Boost pressure:
Date converted:
Problems during build (or least favourite part :p):
any running issues encountered:
any RR printouts to support!
feel free to add any other headers for useful info that I may have missed along the way.
Edited by rob_sri (see edit history)
  • Replies 52
Posted Images
ill throw a few of the different ones ive done out there
Internal engine Mods (inc head work, cams etc): oem
Compression Mods: none
Turbo Choice: t61
Wastegate: xs power
intake manifold: oem
Induction: mesh
Exhaust (size + make) inc manifold: xs mani, 3" straight through
Cooling mods: fmic
engine management: emanage blue
Injectors: oem
Ignition mods: 4 runner dizzy 6d.btc
any other electrical supporting mods: none
mapped by: ryan g
boost; 8psi
gearbox: w58
Power: 385bhp
Torque: 350lbs
Boost pressure:
Date converted:
any running issues encountered: broke w58
any RR printouts to support! in one of my old threads somewhere
clutch eaton 6 puk
feel free to add any other headers for useful info that I may have missed along the way. clutch used
Compression Mods: tt pistons. oem head gasket
Turbo Choice: t61
Wastegate: prescision
Induction: mesh
Exhaust (size + make) inc manifold:xs power , 3" toyo sport
Cooling mods: fmic
engine management: e manage blue
Injectors: denso 550. twin oem pumps
Ignition mods: 4 runner dizzy 6 deg btdc
mapped by: ryan g
gearbox: w58 / r 154
Power: 490bhp
Torque:450 lbs
Boost pressure: 15psi
Date converted:
any running issues encountered: comprehensivly destroyed a w58 , fitted r154
any RR printouts to support! somehwhere
f
Compression Mods: tt pistons , oem gasket
Turbo Choice: t61
Induction: mesh
Exhaust (size + make) inc manifold: xs manifold 3" toyosport
Cooling mods: oem tt smic
Injectors: denso 550cc twin wlabro 225s (buuzzzzz)
Ignition mods:
mapped by: htp
gearbox: david p hybrid auto
Power: 510 bhp @ 4600rpm then wheels kept spinning. the tuning shop estimated 560+ by the graph but hard to tell
Torque: 490 lbs up to the spinning
Boost pressure: 20 psi
Date converted:
any running issues encountered: none
any RR printouts to support! in an old build thread
Turbo Choice: garret gt4088 too big for this low boost build , very laggy
Wastegate: xs power
Induction: mesh
Cooling mods: fmic
Injectors: oem
mapped by: ryan g
boost; 8psi
gearbox: w58
Power: 380bhp
Torque: 340lbs
Boost pressure: 8psi
Date converted:
any running issues encountered: garret oil seals failed replaced latter with t61
clutch eaton 6 puk
Internal engine Mods (inc head work, cams etc): OEM
Compression Mods: OEM
Turbo Choice: T61
Wastegate: HKS COPY 50mm 7psi spring
BOV: HKS
intake manifold: OEM
Induction: 4" K&N
Exhaust (size + make) inc manifold: 4" DP AND MP WITH FLEXI SECTION, XS POWER MANIFOLD TITANIUM HEAT WRAPPED
Cooling mods: 600x300x76 FMIC eBay (toyosport)
engine management: E-MANAGE ULTIMATE 3BAR MAP SENSOR
Injectors: OEM 330cc but recently purchased mk3 440cc walbro 255 fuel pump
Ignition mods: 4runner dizzy cap
any other electrical supporting mods: AEM TRU BOOST GAUGE/CONTROLLER AEM AFR GAUGE, DEPO OIL TEMP + PRESSURE GAUGES
mapped by: TUNING DEVELOPMENT http://www.tuningdevelopments.co.uk/
gearbox: W58
clutch: SPEC STAGE 3 fidanza lightweight flywheel
Power: 260 :( hoping for near 370 this time!
Torque:
Boost pressure:
Date converted:
Problems during build (or least favourite part :p): forgot to tighten intercooler pipe before I had it mapped resulting in boost problems, removed wastegate to pressure test to find it had the wrong spring installed!
any running issues encountered: N/A
Edited by ballsdeep (see edit history)
  • 2 weeks later...
Mine is going to Paul at Whifbitz tomorrow. Using his new NA-t kit plus ordered in a boost logic auto box and other parts, will be changing for TT pistons and other parts.
The aim is 500-550bhp for the build.
Once I get more details on all parts we decide, plus pics and dyno graphs I can update :)
Sorry to be lazy mate but I'm going to copy mine over from a document I saved on my computer if that's okay? If not I'll reconfig it under your headings.
Engine:
2JZGE 2997cc
XS Power T61 Turbo
XS Power tubular manifold wrapped in Thermotec heat wrap
3” Downpipe wrapped in Thermotec heat wrap
3” Decat pipe wrapped in Thermotec heat wrap and straight through TRD style exhaust system
1.3mm 2JZGTE head gasket
Head stripped and reassembled with new stem seals and lapped valves
650CC Siemens DEKA injectors with custom pigtails and shimmed fuel rail
4” Intake pipework
4” K&N air filter
3” Core Toyosports intercooler
2.5” & 3” Custom intercooler pipework
38mm Tial style wastegate with 7.5psi spring
Toyota 4 Runner distributor cap with additional no.2 HT lead
Open screamer pipe wrapped in Thermotec heat wrap
AN10 Braided oil return with billet AN10 flange
Braided oil feed hose with 3mm oil restrictor
Blue anodized oil filter sandwich plate with 1/8th NPT threads
Modified oil pan with billet AN10 flange fitted for oil return
Air condition delete
Power steering “up” system delete
ACIS (acoustically controller induction system) and butterfly removed
Shortened auxiliary belt
T4 turbo blanket
Custom painted red engine block
Custom painted silver engine covers, engine mounts, ancillaries and inlet manifold
Fuchs Titan Race Pro S 10W50 engine oil
Toyota red coolant
Walbro 255 fuel pump with fuel resistant heat shrink on all soldered connections
Fuel pump ECU bypass for consistent 12V oppose to stock 9/12V switching
Fuel damper delete with braided hose and AN fittings
Single O2 sensor conversion
Emanage Ultimate piggy back ECU mapped on Shell V Power
112MPH Speed cut removed
3 BAR MAP sensor
Drivetrain:
W58 five speed manual transmission
Competition Clutch Stage 5
AO1B Torsen LSD
Motul Gear 300 75W90gear box oil
Motul shockproof 90W differential oil
Mapped by:
Lyndon (mkivsupra.net member)
Power, Torque and Boost Pressure:
7.5psi, power figures unknown at present. Boost will be upped to 1 bar soon.
Date completed:
31st August 2013
Problems during build (or least favourite part):
Exhaust manifold stud thread was stripped inside the head so had to V Coil the head to fit a new stud and the oil return line is awkward to fit under the turbo. Lastly, one I don't see mentioned much, the oil return flange I used sat quite proud of the side of the oil pan meaning it caught on a thread for the power steering rack. Any issues encountered were all easily sorted :thumbs:
Running issues encountered:
Scares young children and old people :D
Edited by Rich.2211 (see edit history)
2jzge 100 000
5-30w fully synthetic oil
Internal engine Mods (inc head work, cams etc): ARP head bolts + serviced IAW TSM
Compression Mods: tt headgasket 1.2mm
Turbo Choice: t61 oil feed from Lexus Union bolt and braided line using 3mm oil restrictor. Oil return tapped in top of sump casting, different to usual but works fine, line covered in fire proof sleeve.
Wastegate: xs power 50mm- modified screamer pipe covered in thermo wrapp.
3inch downpipe covered in thermo wrapp
intake manifold: oem painted black
Induction: K+N with cold air tube routed to filter
Exhaust : Nurspec R cat back, 3 inch
Cooling mods: fmic, 10 Row oil cooler from sandwich plate, AEM water meth, pre TB 630lph jet 50/50 mix
engine management: emanage Ult + 3bar map sensor + O2 sensors replaced with simulated narrowband from wbo2.
Injectors: 7mGTE 440s + 6ohm resistors
Fueling - Aeromotive FPR , 4 BAR fuel pressure, Walbro 255 fuel pump, 12V mod, fuel pulsation removed.
Ignition mods: 4 runner dizzy, new rotor arm, new leads
other electrical supporting mods: mtxl WB02 gauge and data log, Greddy profec b boost controller , A working electrical drivers seat, oil temp gauge - sensor in sump. Boost gauge. AEM boost safe connected to power supply of boost controller allowing system turn off if water meth shows a fault, backs to 7psi spring pressure.
Water on LED.
mapped by: Dynotune ripley (they were shit) may as well have mapped myself, actually I did!
Austec racing (great guys but issues with fueling)
boost; mapped on road to 12 psi AFRs at 10.5
gearbox: V161 with CC stage four six puck clutch + lightweight flywheel + ARP flywheel bolts
Other standard SZR parts such as Torsten diff, bilstein suspension etc.
Intake/cam covers/ pipework colour coded in black/white.
Lightweight power steering/ alternator/ aircon pulleys - stock crank pulley
Power: ?
Torque: ?
Boost pressure:12psi
Date converted: still ongoing
Problems during build (or least favourite part :p): lean running, a wiered flutter noise from turbo/exhaust cam, having a tiny garage, removing the sump without engine or sub frame being removed, gearbox removal, head replacement. Stripped head bolt.
*update* flutter appears to be from a gap between turbo and manifold.
The gearbox removal was an utter pita, have a friend help and get a head bearing removal tool.
Removal of the head is probably easier with the engine out otherwise to get some of the lower runner bolts requires removal of the starter motor.
Found a stripped head bolt as I was removing the head, requires drilling out and removal of all swarf.
any running issues encountered: Running lean due to injector resistors being wrong( now fixed), Variable fuel pressue - tube from pump to hanger split and was leaking.
any RR printouts to support! one at 250BHP at Dyno tune running 5 cylinders but mega lean.
Edited by Fly (see edit history)
Rich I just noticed you don't have the mahoosive crash bar on the front of your car, did you remove it?
Yes mate I removed it, the intercooler sits quite far forward and I want to make some proper ducting up for it and the crash bar was in the way.
Edit - Just an update to this post.. I've now bought a new crash bar and bumper foam as I wasn't happy without it and it made the front bumper sag.
  • 1 month later...
Turbo Choice: AR.70
Wastegate: HKS COPY 38mm 7psi spring (may be changing to hks 50mm)
BOV: SSQ Copy
Induction: 4" K&N
Exhaust (size + make) inc manifold: XS Power Manifold + 3" full custom stainless
engine management: Link G4 Plug-in ecu 3 Bar map sensor
Injectors: OEM currently changing to 550cc Denso's before i got for next map
any other electrical supporting mods: Boost Guage, AFM guage, Oil pressure guage
mapped by: Initial tune done by Infomotive, (New Zealand)
gearbox: W58
clutch: CI Heavy Duty
Power: 250kw ATW (350ish HP at 14 psi)
Torque: Acording to Dyno Sheet like 900nm but i think thats wrong
Boost pressure:14 psi (over boosting currently i think WG is broken )
Date converted:Ongoing
Problems during build (or least favourite part :p): Kit didnt all fit together nicely most things needed small modifications to fit, wastegate not working properly
any running issues encountered: Over Boosting Currently, link imposed 4600rpm limiter so as not to damage internals, ongoing issues with this
  • 2 months later...
Thought this would be a good way too keep progress of what I'm doing to the car and also a good way to show people :)
I'm going for between 500-600bhp have to see what it dyno on the day
My specs/parts...
Low mileage n/a engine 60000 97facelift
Billet fuel rail sard
Battery to boot
Billet water pump pulley cover
Stainless steel bolt set for various engine bits
Fuel pressure regulator
Bradded fuel lines
5mm pipe for bov/wastegate/boost controller 5m plus
Tee pieces x3 for 5 mm boost hose
Willbro 255l fuel pump
Turbo blanket
alloy rad
Oil sandwich plate
3" Turbo inlet pipe
Spark plugs x6
Opieoils engine, diff, gearbox oil, and filters
ARP Head studs
Greedy E-manage ultimate
3bar map sensor
4 runner dizzy cap
N/A gasket set
TT head gasket
60mm wastegate hks rep
Aem air/fuel gauge
wideband o2 sensor
Aem egt gauge
injectors 650cc
2jz ge manifold with t4 flange
hks ssqv bov
depo boost gauge with volt meter oil temp and oil press
blitz dual boost control
all fmic pipes work 3"
fmic 3"
blitz air filter
Polished T61 turbo
Bradded Turbo oil lines
Single turbo down pipe
Second decat pipe
3" inlet pipe for turbo
3-4 reducer for turbo inlet
3" v band clamp for down pipe
Piping for screamer pipe
Twin electric fan kit
16row oil cooler and pipes
TT inlet manifold in black
TT cam covers with 10an breather fittings sprayed same colour as car
TT Black spark plug cover
Magnecor 8mm ht leads
Stainless steel fmic cover plate
Cnc machined rad brackets
Trd oil cap
2 inlet catch can
TT idle control valve
TT throttle position sensor
TT throttle cable
Polished aux pulleys
all hoses and an fittings
Drive gear ...............................
r154 gearbox
brand new r154 stage 3 clutch
brand new r154 flywheel
brand new r154 slave
r154 front of prop shaft
chaser speedo sensor
modified shifter housing
r154 gearbox mount
LSD
and any other bits needed
Various nuts and bolts
Engine just before it went in the car
Progress pics
Edited by buster (see edit history)
Engine
3000cc Straight 6 2JZ-GE
T61 Turbo
T4 Titanium Turbo Blanket
HKS 50mm external wastegate & screamer pipe
XS power turbo manifold
3" v-band downpipe
TRD replica 3" exhaust
Whifbitz 3" 2nd decat
Oil filter sandwich plate
Whifbitz oil feed and oil drain lines
440cc injectors (with resister pack)
Wolbro 255 fuel pump
TT 1.3mm headgasket (lowered compression)
Large 3" FMIC
3" Intercooler pipework
HKS SSQV BOV
4" intake pipe
4" K&N Filter
BKR7E plugs
Toyota 4 Runner dizzy cap
No2 lead to replace no1 lead
Drivetrain
W58 5spd manual
SPEC stage 3 clutch kit
A01B LSD
Suspension, Wheels, Tyres & Brakes
Stock Bilsteins
Jspec Brakes
18" Bronze Rota GRID Drift (8.5J fronts & 10J rears)
Pirelli P Zero ROSSO (235/40/18 front, 275/35/18 rear)
Electronics
GReddy 3 bar map sensor
GReddy E-manage Ultimate Piggy Back ECU
GReddy temperature sensor
AEM Wideband gauge
AEM Tru Boost controller
AEM oil temp gauge
60mm oil pressure gauge
Thor shows 427hp 370 lbs/ft @ 14.5psi
DynoDaze shows 393hp 360lbs/ft @ 10psi
Will be back to dynodaze for a run on full boost to compare all
Edited by berg (see edit history)
Intrigued on how well the emanage coped with larger injectors. I thought it didn't control them too well.
Not sure about Blue but my Emanage Ultimate controls my 650cc Siemens DEKA injectors perfectly. Starts, cold starts, idling etc. just as it did when it was NA :)
