theredone Posted September 15, 2013 Share Posted September 15, 2013 Wanting to turbo my na supra Would a gt30 or gt35 be suitable for a supra or t04b-e Want the max power on standard internal Whats the max boost? And max power the standard engine can take? Quote Link to comment Share on other sites More sharing options...
Tsia Posted September 15, 2013 Share Posted September 15, 2013 Search function is your friend Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Am i searching that on here because ive just tryed it and nothings come up Quote Link to comment Share on other sites More sharing options...
abtin90 Posted September 15, 2013 Share Posted September 15, 2013 A garrett gt35 is an ideal for an na-t setup. That's what I'd go for. A lot of members lately have been using the xs power t61 with good results and they seem to all be holding up fine. I'd personally go with a quality second hand one if your on a tight budget. Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Okay mate whats the bigger turbo the na can run i want the biggest and most power new to supras the na feels way to slow Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Ive also been looking at gt45s would that be to big ? Quote Link to comment Share on other sites More sharing options...
Al Massey Posted September 15, 2013 Share Posted September 15, 2013 Have a good search, there is plenty of build threads and discussions on this. Also look at garage whifbits he does a full kit Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Ive looked mate and cant find anything really im building a kit my self mate gt45 turbo if that would be okay to use Quote Link to comment Share on other sites More sharing options...
kill1308 Posted September 15, 2013 Share Posted September 15, 2013 You're limited on the boost you can run without making internal changes to the NA block, so Turbo choice is critical dependant on your goals in my opinion. I'd strongly suggest finalising your end goal power wise, then doing more research before you choose any components. Also consider cost/time/labour and whether or not it's worth just flogging the NA and buying a TT. Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Yeah mate im not doing it yet as ive got to get more info Im not bothered how much its going to cost me in labour etc Im going for the na/t as im not willing to sell and go for a tt Just need to know things like would a gt45 be suitable and or any sugestions on what turbos would be good Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Im looking for around the 400 bhp mark aswell or if its possible to go more on the standard internals id like more Quote Link to comment Share on other sites More sharing options...
Pulley Posted September 15, 2013 Share Posted September 15, 2013 Without lowering your compression ratio (changing headgasket to a TT one) your limited to a max of 1bar boost Or you'll have det issues You can stick any size turbo on , but bigger spools slower and unless your going for 750 + where you'd need to upgrade internals A t4 flange manifold will support most the turbos you'd ever want to run , so I'd start with a T61 / T67 and see how that feels (600bhp ish) Not too laggy and you can drive on 1bar boost until you lower compression Also if your running a w58 manual box it's limited to 400 ishbhp And I'm not sure wot an NA auto box can take either 400bhp is pretty quick mind you I'd go for a t61 size turbo for drivability and performance that won't require too much supporting mods spent other than piggy back and fuelling Quote Link to comment Share on other sites More sharing options...
rob_sri Posted September 15, 2013 Share Posted September 15, 2013 Im looking for around the 400 bhp mark aswell or if its possible to go more on the standard internals id like more as far as im aware 400hp is easily achievable on stock internals.. some people may also run the TT head gasket to lower compression a bit and allow you to run more boost and still have slightly higher compression than a GTE however 400+bhp on the W58 (na manual 5 spd box) is likely to shit itself with some abuse.. this is not something i've done but I will be looking to do in the future after some supporting upgrades..so I'd also be interested to know peoples power/compression changes/wastegate and turbo set up too.. if people wouldnt mind posting a quick spec of their NA-T that would be useful.. Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Okay ill look into that mines a auto box would the clutch etc need change for 400 bhp ??? Quote Link to comment Share on other sites More sharing options...
Littler Posted September 15, 2013 Share Posted September 15, 2013 Okay ill look into that mines a auto box would the clutch etc need change for 400 bhp ??? The NA autobox will not take 400bhp as far as I'm aware, you'd need to consider a TT autobox or a hybrid unit... Or go manual of course Quote Link to comment Share on other sites More sharing options...
theredone Posted September 15, 2013 Author Share Posted September 15, 2013 Okay mate ill try and source something Quote Link to comment Share on other sites More sharing options...
