BMW 330 Ci M Sport Convertible
Dnk
E46 2004 330 Ci M sport convertible auto
Sapphire Black
Black leather interior
Black roof
80100 miles
2 previous owners
MOT March 2020
BMW stereo with single disc player in car & 6 disc
player in the boot
Lots of history including BMW service history, independent
specialist NCB Autokraft and my local village garage who looked after my Supra
All previous mots
HPI checked
Original owners wallet with handbooks etc
2 sets of keys
Rear parking sensors
EW, EH, ES, EM
Air con
Traction control
Cruise control
Multi function M sport steering wheel
I've owned this car for over 7 years and it's never missed a beat, in 2015 i did 3000 + miles in Europe and it was faultless. Very recently its had all new brakes fitted and has just had a refresh of the cooling system, the car was running perfectly prior to this and was purely a precautionary measure against failing rads, ex tanks water pumps etc which are known weak points
Dec 2013
New Bosch battery fitted and new drivers door
locking mechanism supplied by Sytner BMW
May 2014
New front lower control arm bushes fitted (OE) along with oil & filters change
Shell Helix fully syn, OE filter and rear brake pads.
Complete new drivers door mirror fitted due the common wiring ribbon breaking supplied
by Sytner BMW
April 2015
Passenger airbag recall done at Sytners
Oct 2015
Professionally refurbished front brake calipers inc new pads and brake fluid change
March 2016
Oil level sensor replaced along with oil & filter change, Shell Helix Ultra, OE filter OEM sensor
May 2016
Fitted 18" staggered fitment Racing Dynamics RD2 alloys
Dec 2016
fitted the Stealth HID kit from HIDS4U, 35W 5000K
Sept 2017
Drivers airbag recall done at Sytners
Sept 2017
New cam cover seal kit OE, new crank case ventilation kit OE,
new NGK BKR6EQUP plugs, pollen filter, air filter, front brake hoses
Sept 2017
Four wheel alignment done at Silverline wheels & tyres Warwick
Sept 2017 68,000 miles
Wheels refurbished along with 4 new Vredestein Ultac Vorti tyres fitted, last 3 photos taken after the refurb with a brighter silver powder coat
Nov 2017
Gearbox ATF changed at Transmission Technology Knowle Solihull
Nov 2017
Key refurbished by the Master Locksmith
Dec 2018
Oil filter housing O ring replaced
Aug 2019
Front discs & pads, rear discs & pads, hand brake shoes
Nov 2019
Radiator (Nissens), Water pump (OE), Expansion tank, sensor & cap (OE), Thermostat (OE), Viscous coupling (Febi Bilstein), Aux belt & AC belt Belt (Gates), Water hose 1 (OE) and Water hose 3 (OE), Expansion tank O ring (OE) Expansion tank Thermostat (OE)
Nov 2019
Shell Helix Ultra fully synthetic LL04, Oil filter (OE), Differential fill & drain screw plugs with O rings, 75/90 fully syn diff oil, air filter, Coolant, Air filter
June 2020
New windscreen and trim fitted also new Bosch wiper blades
July 2021
August 2021
DSC sensor on master cylinder replaced with new OE
Eibach Pro kit springs fitted
New rear brake calipers
£4995
Now in the first post, i'd not finished writing the advert :)
Sorry mate. Lol
I'm glad it's priced as it is. Because if it'd have been £1000 cheaper i'd have kicked you in the nuts with your own shoes as it was a toss up between one of these and an RZ TT and I just bought the RZ because I couldn't find EXACTLY the car you're now selling. But it's ok. It's just about outta my price range. Lol
Sorry mate. Lol
No problem Ben :)
I looked for quite a while to find a nice 330 M sport with low miles
in Black with black interior.
Also on P/H
  • 2 weeks later...
  • 2 weeks later...
  • 4 months later...
  • 3 weeks later...
If your thinking about getting one join the forums, as usual everything you need to know will
be on them.
Any car i'm thinking of buying i just google them, e46 320d reviews will bring up the usual
replies, good oil change history req, turbo failures, swirl flaps, rear subframe problems etc
Most diesels will be high mileage, if your not doing the miles then it's not worth buying
diesel in my opinion, i can get over 30 mpg out of my 330 above
Here's a few of them worth looking at
http://www.e46zone.com
http://www.e46fanatics.com
http://www.bimmerforums.co.uk
  • 3 weeks later...
  • 2 weeks later...
I've removed the advert from P/H for now
Wheels are at Ibrars getting fully refurbed along with new centre caps and M badges.
Also fitting 4 new Avon ZZ5 tyres, new front lower control arm bushes, rear pads, air filter,
oil filter & engine oil.
Will update first post with latest photos etc
  • 2 weeks later...
  • 2 weeks later...
  • 1 year later...
  • 3 months later...
