Apexi neo exhaust
C_Strike
hi everyone. need a bit of help trying to establish whats going wrong whilst trying to fit an apexi exhaust i bought recently from a forum member and was hoping for some help and advice.
the exhaust is fitted but not very well at all.
has anyone got any pictures of an apexi fitted on theirs? il try to get some pictures up.
to me the 'hook' (bracket attached to car) looks like its useable on both sides. there is a slight difference between the two hooks which led me to think the rubbers are of a wrong design or the hook in use has been slightly modified to fit.
the exhaust certainly has enough play to manouver it to the correct position, its just keeping pressure to keep it there. so maybe turning around the bracket? i think just changing the exhaust strap round wont keep enough pressure to keep in position and will potential pull itself free of the bracket? tho it should position it better
Keep the bracket on the exhaust the way it is. Get a universal rubber exhaust ring, and (looking from the back) hook it over the left hand "hook" on the car bracket, and over the bracket on the exhaust. I very much doubt it would pull off. If anything, there would be more pressure, making it less likely.
Like so:
Edited by listy (see edit history)
I`ve been thinking a little more about this and am pretty sure that this is a two piece exhaust. Why would you have a moveable bracket on the rear silencer if the silencer was not moveable in relation to the front silencer, which has a solid welded bracket? Most after market exhausts are two piece for ease of shipment and alignment.
well the picture in post no2 with the exhaust on me dogs quilt(sorry dog) shows the exhaust. everything in the picture is one piece. i did wonder if the decat set the rest of the exhaust at a funny angle.. maybe it was modified to fit the old exhaust? only time iv previously chamged the exhaust was for an oem and that fit without problems as youd expect.
