Rob_Mitchell Posted September 26, 2013 Share Posted September 26, 2013 Thats stunning! very nice James Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 26, 2013 Author Share Posted September 26, 2013 http://www.ccwheel.com/wheels-display.php?view=K57 Really tempted to get some of these centres made up to fit the wheels… then I can swap them if I fancy a change! or possibly these…. http://www.ccwheel.com/wheels-display.php?view=LM5 Link to comment Share on other sites More sharing options...
James Posted September 26, 2013 Share Posted September 26, 2013 Cheers Dude! 10.5 fronts and 11.5 rears mate. No Idea on the offsets.. they're CCW's Supra Fitment.. but the rears don't need a 10mm spacer.. so -10 more offset than usual. 18's front and rear. Don't like the look of the staggered setup really... for the power I want traction will be acceptable! Supra fitment don't require a 10mm spacer anyway - it is just a 3mm spacer up front for caliper clearance on UK brakes (on the Classics). +50 Link to comment Share on other sites More sharing options...
James Posted September 26, 2013 Share Posted September 26, 2013 http://www.ccwheel.com/wheels-display.php?view=K57 Really tempted to get some of these centres made up to fit the wheels… then I can swap them if I fancy a change! or possibly these…. http://www.ccwheel.com/wheels-display.php?view=LM5 Just as an FYI (it may be different for the LM20, I'm not sure ): James, Unfortunately not something that is possible. Sorry. Jonathan On 24 May 2013 07:15, James wrote: Hi there, I have recently had an order placed for 'Supra Fitment' Classics in 18x10/18x11.5. What I am wondering for future reference is whether the LM5 wheel pieces are to the same spec as the Classics? In other words, if I was to buy the LM5 centres, can I rebuild the 3pc wheels with these centres and they would work out the same as if I had ordered LM5 wheels for Supra fitment in the first place? I am unsure as to whether the backspacing etc. was the same or not, hence my query! If it IS possible to do so, can you provide me with a price for the LM5 centres ONLY in 18". Thanks very much! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 26, 2013 Author Share Posted September 26, 2013 Supra fitment don't require a 10mm spacer anyway - it is just a 3mm spacer up front for caliper clearance on UK brakes (on the Classics). +50 Ok.. I thought there was a difference as you were saying yours still rub a little? Mine haven't rubbed yet and the roads where I live are pretty crap.. If they going to catch it's going to be on the rear lower plastic bit. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 26, 2013 Author Share Posted September 26, 2013 Just as an FYI (it may be different for the LM20, I'm not sure ): Hmm I wonder why they won't do that? Complete Custom Wheel implies that they can/should be able to make you just about anything? Link to comment Share on other sites More sharing options...
tkddav3 Posted September 27, 2013 Share Posted September 27, 2013 Looks great lad Link to comment Share on other sites More sharing options...
Camry5Sgte Posted September 28, 2013 Share Posted September 28, 2013 This car looks rubbish!!! There are no paint chips and he has actually mounted that front license plate!!! Link to comment Share on other sites More sharing options...
Pudsey Posted September 28, 2013 Share Posted September 28, 2013 I always knew they were going to look stunning. Certainly glad they went straight on without any issues, certainly makes the car look all that bit more special. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 29, 2013 Author Share Posted September 29, 2013 Small Update- -Facelift Engine mounts in the bin! Good Pre-Facelift set fitted. So, so, so much better! Before the car vibrated like a b*tch at idle and especially when moving in reverse. Much better. Pic from today post Japshow.. Collecting bits from my house. Link to comment Share on other sites More sharing options...
Justin Bieber Posted September 29, 2013 Share Posted September 29, 2013 If only I'd planned that picture better, your garage door was open at this point, could of had a cheeky snap of Eleanor too! Link to comment Share on other sites More sharing options...
Littler Posted September 30, 2013 Share Posted September 30, 2013 James you did not get my good side at all Have to say I went out in this car yesterday around some great twisties, it really does drive well!! And the stance from the rear is spot on with the ride height and CCW's Link to comment Share on other sites More sharing options...
Sheefa Posted September 30, 2013 Share Posted September 30, 2013 James you did not get my good side at all Have to say I went out in this car yesterday around some great twisties, it really does drive well!! And the stance from the rear is spot on with the ride height and CCW's Looks like you're taking a p1ss on your car mate to clean off those little midges - not your little midge We know how anal you are about cleanliness Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 30, 2013 Author Share Posted September 30, 2013 Reply from CCW… Winning! ********************************************************************************** Hi James you can change the centers, and use lm5's instead of lm20's. new polished centers are going to run 325 each polished, black powdercoat will add 40 per center if you had amirs last name I can reprint his work order john ********************************************************************************** Roughly £1200 for a completely different wheel style then. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 8, 2013 Author Share Posted October 8, 2013 Found this from Japshow Finale... Thought it was worth a share. Link to comment Share on other sites More sharing options...
drift_bear Posted October 8, 2013 Share Posted October 8, 2013 Link to comment Share on other sites More sharing options...
Westy Posted October 8, 2013 Share Posted October 8, 2013 Looking good mate. That's good news re the CCWs. Link to comment Share on other sites More sharing options...
thetrashcanman Posted October 8, 2013 Share Posted October 8, 2013 Looks awesome dude! saw this at bluewater Friday and she looks amazing in the flesh! Shall have to try and get some pictures if it's dry and you at bluewater next month mate Link to comment Share on other sites More sharing options...
clay Posted October 8, 2013 Share Posted October 8, 2013 It is a lovely motor mate. NOW take the wheels back off and paint the blo@dy brakes Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 8, 2013 Author Share Posted October 8, 2013 It is a lovely motor mate. NOW take the wheels back off and paint the blo@dy brakes They'll be getting changed before they get painted Link to comment Share on other sites More sharing options...
James Posted October 8, 2013 Share Posted October 8, 2013 Reply from CCW… Winning! ********************************************************************************** Hi James you can change the centers, and use lm5's instead of lm20's. new polished centers are going to run 325 each polished, black powdercoat will add 40 per center if you had amirs last name I can reprint his work order john ********************************************************************************** Roughly £1200 for a completely different wheel style then. That is awesome news! Lucky for some Must just be the Classics that suffer otherwise! Ace. Link to comment Share on other sites More sharing options...
Abz Posted October 8, 2013 Share Posted October 8, 2013 I heard this beast at Bluewater when Bieber & James went out for a spin, it sounded freaking awesome!! Goes like the clappers too Link to comment Share on other sites More sharing options...
thetrashcanman Posted October 8, 2013 Share Posted October 8, 2013 I heard this beast at Bluewater when Bieber & James went out for a spin, it sounded freaking awesome!! Goes like the clappers too How was biebers car Abz? Enjoy TTC? Link to comment Share on other sites More sharing options...
Abz Posted October 8, 2013 Share Posted October 8, 2013 How was biebers car Abz? Enjoy TTC? His car is freaking awesome, I am telling you it is very quick considering it is a TT! I can see this easily getting into the 12's James was kindly going to put my car into TTC as I have an issue with one of the VSV's but we didn't have no silicon pipe Link to comment Share on other sites More sharing options...
David P Posted October 8, 2013 Share Posted October 8, 2013 James was kindly going to put my car into TTC as I have an issue with one of the VSV's but we didn't have no silicon pipe Link to comment Share on other sites More sharing options...
