ripped_fear Posted September 30, 2016 Share Posted September 30, 2016 great work buddy, looks the part Quote Link to comment Share on other sites More sharing options...
Supraleeturbo Posted October 1, 2016 Share Posted October 1, 2016 Looks lovelymate Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 6, 2016 Author Share Posted October 6, 2016 Progress! -ST205 Throttle Cable Sourced -TB in progress at the engineering shop -Injector 14mm top hats are in the post. Current Status: Valve covers need some mods and polishing next! Quote Link to comment Share on other sites More sharing options...
JamieP Posted October 6, 2016 Share Posted October 6, 2016 Very nice. Quote Link to comment Share on other sites More sharing options...
Mugello Posted October 6, 2016 Share Posted October 6, 2016 Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 6, 2016 Share Posted October 6, 2016 looks lovely mate, you must be very pleased. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 3, 2016 Author Share Posted December 3, 2016 Plenum install finished! I was waiting on the last few bits to arrive, including getting the TB back from the machinists. O-ring groove in the back of the TB to remove the need for a gasket, other works to the TB include- -Adapter making for supra TPS -New butterfly shaft was made for the new TPS -Butterfly bearing apertures machined deeper so I could fit seals onto the shaft to stop boost leakage via the bearings. Also had to modify the IC pipe up to the TB, shorten and increase it's angle. New PHR PAS pump adapter fitted, to clear IAT sensor in bottom of TB. Because of this I decided to move the reservoir to under the engine box in the corner of the bay. All back together! Quote Link to comment Share on other sites More sharing options...
Fitz Posted December 4, 2016 Share Posted December 4, 2016 Looking good Mr. Jefferson. Whats next on the 'To-Do list' Quote Link to comment Share on other sites More sharing options...
Mugello Posted December 4, 2016 Share Posted December 4, 2016 Top work Quote Link to comment Share on other sites More sharing options...
Parry_10 Posted December 4, 2016 Share Posted December 4, 2016 Need to have the cam covers and turbo housing polished, just saying Quote Link to comment Share on other sites More sharing options...
Sheefa Posted December 8, 2016 Share Posted December 8, 2016 Looks great mate. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 17, 2016 Author Share Posted December 17, 2016 (edited) Little bits have happened; -Shiny Turbo -Cam cover baffles drilled and tapped -Fittings ready to weld -cam covers will be polished afterwards Edited December 17, 2016 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 24, 2017 Author Share Posted January 24, 2017 Latest shiny update, allmost there on the cosmetic front! Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 24, 2017 Share Posted January 24, 2017 good work jeffers Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted January 24, 2017 Share Posted January 24, 2017 She's looking stunning mate Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 24, 2017 Share Posted January 24, 2017 Very nice mate. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 13, 2017 Author Share Posted April 13, 2017 Mapped, it's awesome, roll on Dragonball! Quote Link to comment Share on other sites More sharing options...
Littler Posted April 13, 2017 Share Posted April 13, 2017 Show us the whole dunk plot James, I'm expecting lots of low/mid range torque Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted April 13, 2017 Share Posted April 13, 2017 A little bit more power then. Pump fuel? Look forward to seeing you and the car on DB! Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted November 30, 2017 Author Share Posted November 30, 2017 (edited) Haven’t updated this in ages... not much to report, but I’ve done a few bits! -Picked up an RMR Throttle body, couldn’t resist despite all the work I’d put into machining and making the previous throttle body to IC pipework. I had to make a new pipe and mess around with bosses for the PAS speed valve and the IAT sensor...but it was worth it, it looks ace and matches the manifold. -Made a new centre box to fit the new intake, with customary gold foil. -A friend turned up nice little strap to ensure the IC pipe doesn’t come off again like it did on DB. Thanks to Dom, I borrowed his Tig to weld on the mounting boss. -Also got a nurburgring lap in on DB, and nearly binned it! Got a cheeky pic with Mr. fitz under the sign. Edited December 2, 2017 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted November 30, 2017 Share Posted November 30, 2017 Beautiful car, this and Sheefas UK are 2 of my favourite on the forum Quote Link to comment Share on other sites More sharing options...
Luxluc Posted December 2, 2017 Share Posted December 2, 2017 Nice James Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 30, 2018 Author Share Posted January 30, 2018 (edited) Picked up a C’s shifter, need to try it out see how I feel. Had a bad experience with a B&M one before so I am sceptical. However these are raved about frequently so I’ll give it a try Edited January 30, 2018 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 30, 2018 Author Share Posted January 30, 2018 JasonR24 said: Beautiful car, this and Sheefas UK are 2 of my favourite on the forum Cheers! Quote Link to comment Share on other sites More sharing options...
Josh42 Posted January 30, 2018 Share Posted January 30, 2018 Still my favourite car, you beautiful, half turtle-man! Quote Link to comment Share on other sites More sharing options...
