TheTurtleshead Posted July 2, 2015 Author Share Posted July 2, 2015 Cheers Chris, I'm fond if your old mans car too! Even if it is a slushbox! So here is what the inside of a 6 speed looks like....! I only pulled it apart to re-seal it, but I decided to change the front main bearing as it was Just starting to show signs of wear. Cost me £35 from a local bearing company, for a genuine oem-spec koyo-made bearing, toyota wanted £280+ vat...!!!!! Luckily the rest of the gearbox looks in great condition. Seals turn up next week, hopefully it will be back together then In the mean time I have re-sealed and re-assembled the rear half of the casing. Link to comment Share on other sites More sharing options...
ripped_fear Posted July 2, 2015 Share Posted July 2, 2015 Wow wish I knew as much as you mechanically mate. Looks brilliant James, you really have crated a very nice car! Link to comment Share on other sites More sharing options...
Chris Bailey Posted July 2, 2015 Share Posted July 2, 2015 Thanks James means alot Just a quick question, do you know what size and offsets your CCW'S are? Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 25, 2015 Author Share Posted July 25, 2015 (edited) Just a little update spam...! Found a bit of some kind of broken pin lying in the bottom of my gearbox stuck to the magnet, when I pulled it apart. It turned out to be the fulcrum pin for the 5th/6th selector arm. I don't think it's the original, as it wasn't a good fit in the mechanism, and the head is smaller than the genuine toyota replacement which fits perfectly. Luckily it had snapped half way down as can be seen in the pictures. The top half of the pin was still in the swing arm and amazingly allowing the mechanism to work. My 5-6th change has always been a bit ropey, I'm pleased to report it's now lovely and smooth! Checking the thrust clearance on the new input shaft bearing(was beginning to wear). It shimmed up on the tight side, but should loosen up once the bearing settles in. The new bearing appears to have cured the tiny whine I had when cruising before, so fingers crossed it doesn't come back! The box has had new output, input, shifter, and inner input shaft seals(basically all of them), along with a re-seal of the flanges. Hopefully it'll be oil tight for a long time to come now! After fitting the new LA twin I found that my clutch still wouldn't disengage. I tried a Facelift N/A (Gold/smaller bore cylinder) slave cylinder for more travel, to no avail. I finally found that the issue was a collapsed thrust cone washer on the clutch release hub. This was allowing the hub to vibrate, which I could feel when depressing the pedal. The vibration was transmitting back through the plates in the clutch, causing them to fail to release. She's back on the road! Lovely to be driving her again, the HKS LA Twin is a great clutch, love this car! Edited July 25, 2015 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
Luxluc Posted July 25, 2015 Share Posted July 25, 2015 Good to hear that James. Have fun. Link to comment Share on other sites More sharing options...
abtin90 Posted July 25, 2015 Share Posted July 25, 2015 Love this car and wish I had half your knowledge when it comes to cars. Great work as always. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 25, 2015 Author Share Posted July 25, 2015 Love this car and wish I had half your knowledge when it comes to cars. Great work as always. Cheers bud! Funny, I spend most of my time wishing I had twice as much! Another forgotten update... Brakes were rebuilt and fitted with braided lines and new discs & bolts before Dragonball. Link to comment Share on other sites More sharing options...
ripped_fear Posted July 25, 2015 Share Posted July 25, 2015 Wow more great workman ship James Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted July 25, 2015 Share Posted July 25, 2015 nice feature, but do they know your not twin turbo great car and great works manship gone into this Link to comment Share on other sites More sharing options...
TheTurtleshead Posted July 27, 2015 Author Share Posted July 27, 2015 nice feature, but do they know your not twin turbo great car and great works manship gone into this When they did the first feature withe a few different Supras it was a TT Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 24, 2015 Author Share Posted December 24, 2015 (edited) It's been so mild in the last few weeks, with plenty of rain to keep the roads clean, and warm enough to prevent the gritters emerging in my area...I thought the supra needed #onelastride of 2015. I took some crap pictures, enjoy! Also added a bonus bay pic from the NEC. I have many things planned for the car over winter. Will update as and when I get around to them. Merry Christmas All! Edited December 24, 2015 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
johnny g Posted December 24, 2015 Share Posted December 24, 2015 Epic car mate, just caught up on it. Stunning job. Link to comment Share on other sites More sharing options...
Luxluc Posted December 24, 2015 Share Posted December 24, 2015 Great Supra Link to comment Share on other sites More sharing options...
Abz Posted December 26, 2015 Share Posted December 26, 2015 Looks epic! Loving the engine bay shot! Link to comment Share on other sites More sharing options...
Fitz Posted December 26, 2015 Share Posted December 26, 2015 At least you cleaned it Link to comment Share on other sites More sharing options...
BoostJunky86 Posted January 13, 2016 Share Posted January 13, 2016 Looks amazing!! Link to comment Share on other sites More sharing options...
BoostJunky86 Posted January 13, 2016 Share Posted January 13, 2016 Any interior pics at all? Link to comment Share on other sites More sharing options...
TheTurtleshead Posted March 18, 2016 Author Share Posted March 18, 2016 (edited) I have decided to stop being a fool and keep this car... Hurray! To be honest it made me pretty miserable advertising it for sale in the first place. I don't think I'll find a car this clean again, and I know I'd only start obsessing over owning a supra again about 5 minutes after it drove away.. so without further adieu, the next round of mods are; -I fully washed the underbody, undersealed and cavity waxed the car in the last two days. -I removed and sold the J-spec rear brakes and I am now searching for some UK rear brakes to compliment the AP racing front calipers. More has happened, more is planned, this will do as an update for now. First off I washed the underside, arches, subframe etc... Yes I literally rolled around under the car with a wash mitt, hose and bucket of soapy water. I reasoned that cleaning off all the dirt rather than underselling over it was the way to go for best prep. I then left the car to dry fully before proceeding. I stripped off the sill plates, sill trims, side pods, exhaust heat shields, exhaust.. etc.. Whatever I needed for access. (The marks on the inner rear sill is where the tyre touches... I heated and massaged this a tad with a panel hammer to give a bit more clearance.) I then cracked open the underseal(with added waxyoyl!) It's the stuff that stays slightly tacky and gooey, repelling water for as long as possible. I still need to put the car on a ramp to drop the subframe/petrol tank and finish the under-sealing in the places I couldn't reach... but it will do for now. Finally I cracked open the waxoyl and filled every box section, sill and chassis leg with waxy film. The supra is perfect for this as all the sections have holes and grommets in place to get the wax injection probe in, no need to drill any extra holes to spray into. It's obviously hard to picture the inside of a waxed up sill or box section but I have added a pic of the sill, rear arch join(inner to outer), and the inside of the front sill, so show the waxoyl layer. Edited March 19, 2016 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
supra_ufo Posted March 18, 2016 Share Posted March 18, 2016 I was seriously considering buying this once I had the pennies. Glad your keeping it mate Link to comment Share on other sites More sharing options...
Hammer Posted March 19, 2016 Share Posted March 19, 2016 Glad your keeping this, would have probably gone to Europe never to be seen again otherwise. Love the updates and agree about your knowledge, it makes your updates a cut above the norm. Hope to see it for real at some point. Link to comment Share on other sites More sharing options...
clay Posted March 19, 2016 Share Posted March 19, 2016 Glad you are keeping it mate. Link to comment Share on other sites More sharing options...
MATT RR Posted March 19, 2016 Share Posted March 19, 2016 Glad to hear your keeping it, stunning car Link to comment Share on other sites More sharing options...
TheTurtleshead Posted March 19, 2016 Author Share Posted March 19, 2016 Glad your keeping this, would have probably gone to Europe never to be seen again otherwise. Love the updates and agree about your knowledge, it makes your updates a cut above the norm. Hope to see it for real at some point. Well thanks bud, praise indeed! I'm just a bloke in a shed though, anyone can do it if they want to Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 19, 2016 Share Posted March 19, 2016 I'll be doing the wax oil treatment when mine is complete. People neglect the underneaths a lot when most rot can be prevented a little. Looks great and glad your keeping her Link to comment Share on other sites More sharing options...
Fitz Posted March 19, 2016 Share Posted March 19, 2016 More to add to the list of things to do on my car for you then mate Link to comment Share on other sites More sharing options...
