J Spec Rear brake pad types
The Hornet
Ok I have now found out there ARE two different types of rear brake pads for the J Spec Supra.
The most popular type are Toyota code: 04466-14040
The type I have which appear to be for the 1993-1994 J Spec are Toyota code: 04466-30030
I have attached some pictures of both sets for future reference for people.
Hope this helps others out in the future.
Pics:
http://www.netpostbag.com/~hornet/Supra/rearbrakes/Pict1005.jpg
http://www.netpostbag.com/~hornet/Supra/rearbrakes/Pict1007.jpg
Hornet
I dont know, but just thought would be good idea to have pictures with order codes and sizes up here for future reference :D
No problem with that, but the UK specs are probably the rarer of the 2 (with lots of J-specs in the UK) not the most popular, and the UK spec were an option on J-specs throughout the life of the vehilce, IIRC. So therefore the part number you have for the J-specs are for 1993-2002 (I'm sure that the VVTis can also come with smaller brakes).
Other than that, you are correct :nyah: :eyebrows:
You did indeed post me the Wheel dimension and order codes Colsoop, much appreciated. But if people have (like me) an import with 18" wheels aready on it, you have no idea what the original size wheels where etc etc. Which made it very difficult to establish which type was needed.
Also when you look at the pictures of the pads, most would describe the 30030 pads as being the larger of the too sets. How ever is you work out the surface area of the 14040 pads they are actually the larger ones.
All in all, now there are some pictures with absolute accurate dimensions of the pads plus order codes. Should help people in the same situation in the future without confusion.
