millar11 Posted September 8, 2013 Share Posted September 8, 2013 Looking for bit of clarification, when fitting the lip do u need to remove the complete active spoiler set up or can u just remove the actual blade? Would like to keep the under tray on, that's why I ask. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
ScottC Posted September 8, 2013 Share Posted September 8, 2013 It just replaces the rubber strip under the oem bumper. You'll have to remove the blade, I'm guessing you can get away with leaving the motor in place. The undertray isn't effected. Quote Link to comment Share on other sites More sharing options...
millar11 Posted September 8, 2013 Author Share Posted September 8, 2013 Hey Scott. Yeah that's wot I planned, just leave mechanism on car and just remove the blade. then i will just leave it in off position. It's just in case I change my mind as I will need to see how low the RMM lip sits once fitted. (Also saves unplugging ecu I hope) Quote Link to comment Share on other sites More sharing options...
