Oil
Richienoble
Miller's motorsport cfs 10 60 been using it for few years now tried Mobil1 motorsport that was ok but filled with carbon very quickly
Millers all the way. A 10w-60 will probably be your best bet.
Always used Fuchs Titan pro s, first 5w 40 then changed to 10w 50 as its a little thicker
I also use Fuchs Titan pro s 5w40 fully synthetic, I don't like to use anything thicker as it takes time to warm up/thin out and circulate everywhere .....I like my oil to the top when I turn the key :D
What would be the best engine oil to use in a Supra, specifically a single turbo set up? I'm running the Millers Oils NanoDrive CFS 10W/50 at the moment but as it's time for an oil change I thought I'd find out if this was now the best bet before parting with my hard earned...
From what I understand about engine oil the 10W/60 actually seems like the best of both worlds (same cold start viscosity, etc but with a higher top-end hot temperature rating), but if there's any specific reason why the 10W/50 is still the one to use I'm open to suggestions.
My car is mainly used on the road and occasionally on tracks, if that makes a difference...
Cheers!
I'd stick with a 10w-50. Going to a 60 will slow the flow rate when hot and that can push up engine temps and increase wear due to localised pressure.
I had toyota stuff put in my TT6 iirc and it made a massive difference! Very smooth and quiet now. Bloody expensive though! Over £100 if my crap memory serves me right!
