Jellybean Posted September 5, 2013 Share Posted September 5, 2013 I have 10.5 rears on the car , ideally 275-285 is the width with 295 as max; would putting a 295 on there have any adverse affects other than on my wallet? I am going for a 295 because I am a big kid and 295 rear tyres look better than a 275 the 295'a are only 40 euro more Quote Link to comment Share on other sites More sharing options...
DaveR Posted September 5, 2013 Share Posted September 5, 2013 I think as long as nothing catches on your arches (wheel offset correct, etc) you're good to go. As I understand it wider tyres are better under all circumstances apart from driving through standing water where you have an increase in the chances of aquaplaning. To be honest though I find you have to screw the nut and take it easy in a powerful RWD car in wet conditions anyway... Quote Link to comment Share on other sites More sharing options...
David P Posted September 5, 2013 Share Posted September 5, 2013 What offset? What diameter? What profile? Shane has 10.5 x 18's with 295 35's, arch roll required. I have TTE 10.0 x 18's with 285 40, arch roll required. Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 5, 2013 Share Posted September 5, 2013 What offset? What diameter? What profile? Shane has 10.5 x 18's with 295 35's, arch roll required. I have TTE 10.0 x 18's with 285 40, arch roll required. http://www.mkivsupra.net/vbb/vbpgimage.php?do=full&p=21977&d=1355429043 Jellybeans car is a TRD widebody Quote Link to comment Share on other sites More sharing options...
Jellybean Posted September 5, 2013 Author Share Posted September 5, 2013 thanks guys , yep TRD widebody 295 30 R19 from 275 35 R19, I will will check clearance with the 275's, if in doubt I will stick with the 275 but nearly sure they will have enough room; just dont want to make the handling even worse Quote Link to comment Share on other sites More sharing options...
Dnk Posted September 5, 2013 Share Posted September 5, 2013 I'd stick with the 275's personally Quote Link to comment Share on other sites More sharing options...
David P Posted September 5, 2013 Share Posted September 5, 2013 Jellybeans car is a TRD widebody Next time, I'll remember to add; "What body". Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted September 5, 2013 Share Posted September 5, 2013 305 should also fit a 10.5" wide Wheel Quote Link to comment Share on other sites More sharing options...
