Is there something I'm missing here? O.o
That_Supra_Guy
Noticed yesterday whilst routing around for a possible cause of a clunking noise that there appears to be a diff mounting bush missing (circled in red)?! Or is this correct having only one (Left) side there and I'm being a spanner? It's a manual NA:
P.s I know what you're thinking, but it's just super amounts of mud from the previous owner, I've only just got round to getting a jack stand, so a full clean up underneath is in order next!
  • 2 months later...
I've just had the same panic after jacking up the rear to do a job on my soop today. I thought exactly the same- I thought I had a good drivers excuse for a disappointing end to the season then!
so..... can I retro fit the parts off other soops to add this diffmount in? I plan to swap to an A01B soon anyhow so it would make sense to add the second mount if its easy enough to get the bits and plonk them on whilst I'm under the car.
I haven't found anything else so far in the search so far so a point in the right direction would be appreciated if I've missed something :)
I used a long bolt and some plates I machined up on lathe. My subframe was out at the time though and had no diff or anything in it. I would guess it can be done in situ but you may have to drop the diff as there's probably not enough clearance otherwise
thanks mate appreciate that- i'll go see my Toyota parts man soon and see what he can do. pressing in sounds a pain- what method did you use? combination of plates and clamps? I would rather not drop the subframe if I can help it!
I got mine in with a man sized bearing puller.
But I was prepared to remove the fuel tank to do it, if you'll have the diff out then treaded bar and heavy duty plates will no doubt give you the same result.
superb! nice one pedro. yeah i'll do it from the other side- don't fancy taking the tank out ha ha ;) is the part expensive? just so I don't spit my coffee at mrT when I ask the question.
cheers 2soops but I already have an A01B waiting in the wings ;) I'm sure it will sell quick, sought after for those with an open diff.
ha ha nice one welshbuddy!
