Guest Nutzy Posted September 1, 2013 Share Posted September 1, 2013 Are you guys running a DLI with stock coils Thanks for any help Quote Link to comment Share on other sites More sharing options...
Gpro Posted September 1, 2013 Share Posted September 1, 2013 Dli aint needed with syvecs Quote Link to comment Share on other sites More sharing options...
hodge Posted September 1, 2013 Share Posted September 1, 2013 As sbove, the DLI isn't needed. Quote Link to comment Share on other sites More sharing options...
Guest Nutzy Posted September 1, 2013 Share Posted September 1, 2013 Thanks. Guess I should of said I'll be at about 850whp. Don't know if that makes a difference. I thought that was the case but my tuner said to keep it. When I'm done might just try to disconnect it and see what happens? Quote Link to comment Share on other sites More sharing options...
JamieP Posted September 1, 2013 Share Posted September 1, 2013 I think you will damage your coil packs if you keep it. Quote Link to comment Share on other sites More sharing options...
hodge Posted September 1, 2013 Share Posted September 1, 2013 Thanks. Guess I should of said I'll be at about 850whp. Don't know if that makes a difference. I thought that was the case but my tuner said to keep it. When I'm done might just try to disconnect it and see what happens? The Syvecs can generate enough spark for well over 1000whp, take it out. As Jamie says, you'll fry your coils. Quote Link to comment Share on other sites More sharing options...
Slutters Posted September 1, 2013 Share Posted September 1, 2013 You can keep it if you like, just make sure you dwell settings etc are correct. Although really its just a bandage, get some better coils if you want to run a decent gap. Mojo's for example. Quote Link to comment Share on other sites More sharing options...
Gpro Posted September 1, 2013 Share Posted September 1, 2013 I have personally driven a 850hp supra with syvecs and no dli with no problems Quote Link to comment Share on other sites More sharing options...
Slutters Posted September 1, 2013 Share Posted September 1, 2013 What gap? Quote Link to comment Share on other sites More sharing options...
Guest Nutzy Posted September 1, 2013 Share Posted September 1, 2013 ok thanks. Id like to sell it anyway Quote Link to comment Share on other sites More sharing options...
