Heater matrix removal
charlton
I'm currently half way through and can see the little blighter, I just need to remove the heater box to get to it but it appears to be stuck in the middle.
Is it the pipes that are causing it to stick so it needs a good yank or is there a nut/bolt that's not mentioned and I need to remove? Going by the guide I've got everything, except the pipe on the left which would be showing in the below pic
