Guest davew90 Posted September 1, 2013 Share Posted September 1, 2013 Hi folks, sorry if this has been asked before. Needing to change the clutch on my n/a, how easy of a task is this? Also is there a guide I can follow? Cheers Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted September 1, 2013 Share Posted September 1, 2013 As far as clutch changes go it's as straight forward as they get on the Supra. Plenty of people manage it on axle stands on there drive but best bet and to save your back is to hire a 2 post ramp for the day if it's not to expensive. Quick tip is to remove the fan shroud, slacken off the two engine mounts and tilt the engine backwards to allow you access to the top bell housing bolts. Quote Link to comment Share on other sites More sharing options...
Guest davew90 Posted September 1, 2013 Share Posted September 1, 2013 Cheers bud, I've got my own workshop with 2 post ramp so should be a doddle then. Cheers for the reply. Quote Link to comment Share on other sites More sharing options...
Guest Hosky Posted September 1, 2013 Share Posted September 1, 2013 Any allignment or specialist tools needed? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted September 1, 2013 Share Posted September 1, 2013 3 long extesion bars with woble ends help alot Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted September 1, 2013 Share Posted September 1, 2013 3 long extesion bars with woble ends help alot This!! Quote Link to comment Share on other sites More sharing options...
David P Posted September 1, 2013 Share Posted September 1, 2013 Quick tip is to remove the fan shroud, slacken off the two engine mounts and tilt the engine backwards to allow you access to the top bell housing bolts. Undo one end of the top hose to prevent damaging radiator. Quote Link to comment Share on other sites More sharing options...
Homer Posted September 1, 2013 Share Posted September 1, 2013 It can be done on axle stands, but I wouldn't recommend it and won't be doing it again! Make sure you have the correct clutch alignment tool, I stuffed up on the first attempt as I had a 6spd one... If you have a two poster, some decent length extension bars and a wobble joint it's not too bad a job provided you have a mate or two to help (or better yet a gearbox jack) Quote Link to comment Share on other sites More sharing options...
Pulley Posted September 1, 2013 Share Posted September 1, 2013 Just pulled my w58 out, changed flywheel/clutch and then fitted v160 On axle stands Couple of extensions and wobble joints, decent alignment tools, tilt the engine back I did it on my own (never again) With a post lift and gearbox jack it would be easy as peas Quote Link to comment Share on other sites More sharing options...
