David P Posted September 1, 2013 Share Posted September 1, 2013 (edited) Glug & chuck size plastic bottles are additional and mobile landmines to watch out for in between dodging potholes and kamikaze drivers. Driving a 40 mph stretch at about 40, to make space for an oncoming Audi-loony who was overtaking a bicycle at about 80mph, I had to pull over close to a vicious square edged granite kerb which left insufficient room to manoeuvre out of the way of a Coke bottle that was wafting, dodging and weaving my way and the outside of my front offside tyre just clipped it. It's concerning the damage these things can do, one dead tyre. (I had copperslip on my fingers when I inspected it) Edited September 1, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
fastcar Posted September 1, 2013 Share Posted September 1, 2013 Is that from a plastic coke bottle? Didn't think they would do that kind of damage to be honest Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 1, 2013 Share Posted September 1, 2013 That must have been a plastic bottle with brick inside it! Link to comment Share on other sites More sharing options...
David P Posted September 1, 2013 Author Share Posted September 1, 2013 (edited) Is that from a plastic coke bottle? Didn't think they would do that kind of damage to be honest That's what I said, a glug & chuck sized plastic Coke bottle. Deja Vu. It's a perfect cut to blow out at speed when hot and a death trap to be aware of. Edited September 1, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted September 1, 2013 Author Share Posted September 1, 2013 (edited) That must have been a plastic bottle with brick inside it! Just an empty bottle wafting along the road. Deja Vu Deja Vu. I've seen reports of this before yet only in cold & wet weather, not hot & dry so post up my misfortune as a heads up that could save members lives. Edited September 1, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
DaveR Posted September 1, 2013 Share Posted September 1, 2013 Blimey! Link to comment Share on other sites More sharing options...
Abz Posted September 1, 2013 Share Posted September 1, 2013 Would never have expected that sort of damage!! I assume you had a blowout or did it just leak the air out? Link to comment Share on other sites More sharing options...
gavin.starr Posted September 1, 2013 Share Posted September 1, 2013 If you caught the neck of the bottle i could understand it, they are bloody tough. Link to comment Share on other sites More sharing options...
David P Posted September 1, 2013 Author Share Posted September 1, 2013 (edited) Would never have expected that sort of damage!! I assume you had a blowout or did it just leak the air out? As I said, a perfect cut to blow out at speed when hot, no loss of air at this time. Deja Vu Deja Vu Deja Vu. It's just like a Pikey vendetta cut, up to speed, up to heat and I'll let you work the next bit out. Edited September 1, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
David P Posted September 1, 2013 Author Share Posted September 1, 2013 (edited) If you caught the neck of the bottle i could understand it, they are bloody tough. It was the bottom of the bottle, just clipping the end, but it was either the bottle, the vicious kerb or the Audi. This happened on a dry road and a mark can be seen on the tyre from "1" in 140 to "A" in traction and when the bottle split, the structural strength of it's wonky base must have been enough to drive the broken plastic into the sidewall like a knife and result in the above. Edited September 1, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
