Rev limiter talk
Guest Hosky
errr...... no
- - - Updated - - -
  Digsy said:
I'd assumed he wanted to raise the rev limit too because he broke the rocker arms on his 200.
No mate, bee r rev limiter breaks the rocker arms on the sr20det engine because they are shite, and just windered if they done the same on these engines?
  • Replies 63
  Suprakeith said:
Am happy to answer questions bud so no worries, it wires up to ecu but you just attach the bee r wires so ecu still gets signal and also one wire goes to the handbrake aswell.
Do you know if there would be any difference/issue in adding it to an auto instead amanual???
- - - Updated - - -
  Hosky said:
just been reading about it. only connect white wire to handbrake if you want the use of rev2.
Where is the ecu on one of these cars?
Passenger footwell under the carpet in the corner nearest to the engine
Yea that's correct the rev2 setting is for the launch control rev1 is your cars rev limiter and the 3rd dial is the gain how much you want it to cut which causes the bangs and the ecu is under the foot rest in passenger foot well, lift the carpet and will see plastic box unbolt that and their is ecu on earthing frame.
And cant imagine difference between auto and manual but not 100% on that if honest, would think should be same as its just a rev limiter control box
  Hosky said:
No mate, bee r rev limiter breaks the rocker arms on the sr20det engine because they are $#@!e, and just windered if they done the same on these engines?
You'll be doing well to break the rocker arms on a 2JZ because it doesn't have any. ;)
  Hosky said:
Hello everyone.
Everyone loves pops and bangs right?
No, not right, some of us don't and see them as infantile and attention seeking, and often the sign of a clueless owner with an exhaust leak.
  Quote
Could you stick the bee-r rev limiter on the n/a supra? And wouldn't pop an bang with out breaking something like the rocker arms on my old nissan 200? Doh!
Oh dear..... :(
Can membership be refused on the basis someone sounds like a chav? I once applied to join a Yahoo group and the owner replied, "Sorry, we have to decline your application to join the $$$$$$$$ Yahoo Group on the basis you sound like a clueless ****wit, good day."
I was mortified, and still don't know what I said in the resume. I now laugh about it :) Maybe I asked about pops and bangs...?
