simbasupra Posted August 31, 2013 Share Posted August 31, 2013 Hi Having a little problem bleeding the brakes on a volvo v40. My friend changed a n/s/r caliper and bled the brakes. However he let the reservoir run dry. I have had a look at it and three of the calipers are bleeding fine without any air bubbles, however the o/s/r caliper (not the one he changed) has lots of bubbles which I can't get rid of. I thought running it dry could have got air into the master cylinder but surely that would then affect more than one brake? Any thoughts? Cheers Quote Link to comment Share on other sites More sharing options...
bignum Posted August 31, 2013 Share Posted August 31, 2013 Check the brake pipe to the caliper that was replaced. Quote Link to comment Share on other sites More sharing options...
simbasupra Posted August 31, 2013 Author Share Posted August 31, 2013 Check the brake pipe to the caliper that was replaced. The caliper that was replaced is bleeding ok though. It is the other side that isnt. Could that brake pipe effect the other side? Quote Link to comment Share on other sites More sharing options...
straightsix Posted August 31, 2013 Share Posted August 31, 2013 How long have you been bleeding this line through? Have you followed the correct bleeding sequence? Quote Link to comment Share on other sites More sharing options...
simbasupra Posted August 31, 2013 Author Share Posted August 31, 2013 How long have you been bleeding this line through? Have you followed the correct bleeding sequence? Bleeding it for quite a while, gone through 2 litres of brake fluid. Yes ive done it in the correct sequence. Quote Link to comment Share on other sites More sharing options...
Guest Hosky Posted August 31, 2013 Share Posted August 31, 2013 Bleed all 4 and if the master cylinder has gone dry bleed that aswell. Quote Link to comment Share on other sites More sharing options...
simbasupra Posted September 1, 2013 Author Share Posted September 1, 2013 Bleed all 4 and if the master cylinder has gone dry bleed that aswell. I will give it a try, is the only way to bleed the master cylinder to take it off and bench bleed it? Can it be done without removal? Quote Link to comment Share on other sites More sharing options...
Guest Hosky Posted September 1, 2013 Share Posted September 1, 2013 undo the brake pipes that go onto the master cylinder slightly, as soon as you take it off to bench bleed it then youll be back to sqwuare one again. so undo the brake pipes slightly untill you get some fluid out of it. if it hasnt got seperate nipples Quote Link to comment Share on other sites More sharing options...
simbasupra Posted September 1, 2013 Author Share Posted September 1, 2013 undo the brake pipes that go onto the master cylinder slightly, as soon as you take it off to bench bleed it then youll be back to sqwuare one again. so undo the brake pipes slightly untill you get some fluid out of it. if it hasnt got seperate nipples It hasnt got seperate nipples, so should I undo one pipe at a time or crack both off? Then do I just pump the brake until fluid comes past the threads? Cheers Quote Link to comment Share on other sites More sharing options...
Guest Hosky Posted September 1, 2013 Share Posted September 1, 2013 exactly the same as when you bleed normal brakes mate. veryquick guide 1. open bleed nipple so fluid can come out 2. depress brake pedal (with other person doing it) 3.wait for fluid to come out 4.close nipple 5. release pedal 6. check fluid level as if it goes empty your pushing air in and wasting your time. Hope it helps - - - Updated - - - Oh sorry, and one pipe at a time Quote Link to comment Share on other sites More sharing options...
simbasupra Posted September 1, 2013 Author Share Posted September 1, 2013 exactly the same as when you bleed normal brakes mate. veryquick guide 1. open bleed nipple so fluid can come out 2. depress brake pedal (with other person doing it) 3.wait for fluid to come out 4.close nipple 5. release pedal 6. check fluid level as if it goes empty your pushing air in and wasting your time. Hope it helps - - - Updated - - - Oh sorry, and one pipe at a time Cheers for the info. So as it doesnt have bleed nipples, I guess I should just put some rag under the pipe and bleed it till fluid squirts out. Quote Link to comment Share on other sites More sharing options...
Guest Hosky Posted September 1, 2013 Share Posted September 1, 2013 yes, but dont undo the pipe fully. Quote Link to comment Share on other sites More sharing options...
