Dazzi Posted March 31, 2015 Author Share Posted March 31, 2015 Nice work Thanks Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted March 31, 2015 Share Posted March 31, 2015 great work, wish i had the time to do this.. Quote Link to comment Share on other sites More sharing options...
Dazzi Posted March 31, 2015 Author Share Posted March 31, 2015 great work, wish i had the time to do this.. Thanks. Its taken me a while to do something with them lol! Quote Link to comment Share on other sites More sharing options...
Dazzi Posted April 11, 2015 Author Share Posted April 11, 2015 Finally had chance to install the UK brakes today. The brake heat shield strangely didn't need taking off or trimming and is a perfect fit for the new discs. They were a bit rusty so wire brushed and touched them up with some paint. They look ten times better lurking behind the wheels! Bedding in time now then we'll see how they perform. Quote Link to comment Share on other sites More sharing options...
David P Posted April 12, 2015 Share Posted April 12, 2015 That saved you a windup of a job, looks like it had them before and they were cashed in. Quote Link to comment Share on other sites More sharing options...
Dazzi Posted April 12, 2015 Author Share Posted April 12, 2015 Sure did. I've seen simular 'down grades' with 6 speed getrags which have been cashed in and replaced with the much weaker W58. Not too worried though as I know these calipers are only 7 years old as apposed to 19 years old. Quote Link to comment Share on other sites More sharing options...
Dazzi Posted June 23, 2015 Author Share Posted June 23, 2015 Small update. The downpipe was blowing slightly where it mates with the turbo so I had a flexi section welded in. The slight ticking noise has gone and I can't see any new black soot marks in the turbo blanket. My old exhaust was looking a bit tired and started leaking in several places so I bought a Motoria 3" cat back system off ebay. Also fitted rear upper control arm poly bushes as there was slight play in the pin on the NS. Since fitting the poly bushes to the rear the car is a lot stiffer but the front seems to be a bit bouncy now. When cornering hard or hitting bumps the steering wheel is all over the place. Im hoping this will be solved by fitting front upper control arm poly bushes to eliminate the 'bounciness'. Also fitted a Whifbitz tensioner pulley as the stock 19 year old one got a little noisy. Really good quality, well worth the money. Quote Link to comment Share on other sites More sharing options...
David P Posted June 23, 2015 Share Posted June 23, 2015 That heat wrap won't last long, it'll either suffer instant death from a sleeping policeman or wet & dry rot in a few weeks, it could even force the stainless steel into a ferrous metal surface. Look cool though. Quote Link to comment Share on other sites More sharing options...
Dazzi Posted June 23, 2015 Author Share Posted June 23, 2015 Found that out the other day. A speed bump tore a chunk off the mid pipe. Its coming off shortly. It helps in the engine bay on the down pipe. Might keep that wrapped still. Quote Link to comment Share on other sites More sharing options...
David P Posted July 9, 2015 Share Posted July 9, 2015 It'll be happy on the manifold and downpipe, when are you reducing compression and increasing the boost? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted July 10, 2015 Author Share Posted July 10, 2015 All the wrap is now off. You were right David, the wrap started to change the stainless steel into a rusty brown mess. I used some wet and dry to remove the nastiness and bring back the shine. Just had my MOT. Emissions were fine although the 02 sensor failed 1st time. It was going lean and rich because the values in that part of the map were off . I had to fine tune the map for high idle as it was all over the place! I had an advisory for a front shock misting *cough no gas* so was a perfect opportunity to buy some BC Racing coilovers I've been looking at for a while. Been quite busy this year with a new addition to the family. Looking to drop the compression and up the boost in the new year. Got my list of upgrades ready, I keep hovering over the 'add to basket' but then I remember nappies come first! Quote Link to comment Share on other sites More sharing options...
David P Posted July 27, 2015 Share Posted July 27, 2015 You could boost it to 1.1 bar as is? Quote Link to comment Share on other sites More sharing options...
Dazzi Posted July 28, 2015 Author Share Posted July 28, 2015 On standard compression and Injectors?! Quote Link to comment Share on other sites More sharing options...
David P Posted July 28, 2015 Share Posted July 28, 2015 Stock compression will take up to 1.1 bar of boost, you would need to fit larger injectors. Quote Link to comment Share on other sites More sharing options...
Style Posted July 29, 2015 Share Posted July 29, 2015 Stock compression will take up to 1.1 bar of boost, you would need to fit larger injectors. Really? I always thought you were getting towards the limits of temps and det before 1 bar. Interesting to know I'm guessing a decent oil cooler would be needed along with head studs for that? Hoping to get mine mapped next week and running 650cc's as well as standalone. Just interested to know the best limit to cap it at. Sorry for the hijack Dazzi, now get those parts ordered and the boost cranked! Quote Link to comment Share on other sites More sharing options...
Dazzi Posted July 29, 2015 Author Share Posted July 29, 2015 (edited) Hmmm I think I'll play it safe and stick with the boost the engine was mapped at and increase the boost once I lower the compression and install bigger injectors Update: I mentioned about some BC racing coilovers I was looking to get. Well I got them, installed them and what a difference. I can push the car so much more round corners now. Defiantly one of the best mods Ive bought for the car. Im going to lower the car once everything has bedded in Front Rear All 4 off Edited July 31, 2015 by Dazzi (see edit history) Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted July 30, 2015 Share Posted July 30, 2015 this is always 1 of the first things everyone should do when buying a supra Quote Link to comment Share on other sites More sharing options...
