T14PPA Posted August 28, 2013 Share Posted August 28, 2013 I recently bought a set of 3 piece alloys which has corrosion. Ive been told i should acid dip them before refurbishing them as the corrosion will keep coming through. Can i use nitromorse? Anyone got any advice? Link to comment Share on other sites More sharing options...
naybad Posted August 28, 2013 Share Posted August 28, 2013 Hi I just had to do one of mine was quite easy. Just make sure you clean it up really well and use lots of sealant. I would suggest looking on youtube i found a couple of vids that really helped. Oh and when you put them back together get all the bolts on ASAP I was really surprised how fast the sealant dried. Link to comment Share on other sites More sharing options...
T14PPA Posted August 28, 2013 Author Share Posted August 28, 2013 Hi I just had to do one of mine was quite easy. Just make sure you clean it up really well and use lots of sealant. I would suggest looking on youtube i found a couple of vids that really helped. Oh and when you put them back together get all the bolts on ASAP I was really surprised how fast the sealant dried. Thanks mate but its more the corrosion coming back that im worried about. What sealan did you use? Link to comment Share on other sites More sharing options...
naybad Posted August 28, 2013 Share Posted August 28, 2013 If you clean them properly lots of sanding to get them looking good you could get someone to strip them but i just spent a week sanding it . As long as its High Modulus silicone just use the cheapest i got mine from tool store. Link to comment Share on other sites More sharing options...
T14PPA Posted August 28, 2013 Author Share Posted August 28, 2013 If you clean them properly lots of sanding to get them looking good you could get someone to strip them but i just spent a week sanding it . As long as its High Modulus silicone just use the cheapest i got mine from tool store. Thanks for the advice mate. Link to comment Share on other sites More sharing options...
Guest SL1D3Y Posted August 28, 2013 Share Posted August 28, 2013 Hi mate, Firstly, once corrosion is set in it is difficult to say that you can irradicate it from the metal. Nitromors wont remove corrosion, your best bet it to sand blast them to best erradicate corroded metal, after that sanding them back with finer grades of paper. If you are looking to keep the poished lip i would suggest finishing in 1200-1500 and laquer it to help stop future corrosion problems. Also helps to keep them looking fresh! You can get a sand blasting kit pretty cheap from screwfix for a d.i.y job. Easy to do, just take your time and try to keep blasting material and sand paper as fine as poss for each process. Aerosol primer will tend to only fill 240 grade scratch marks and finer. Hope that helps a little? Link to comment Share on other sites More sharing options...
T14PPA Posted August 28, 2013 Author Share Posted August 28, 2013 Hi mate, Firstly, once corrosion is set in it is difficult to say that you can irradicate it from the metal. Nitromors wont remove corrosion, your best bet it to sand blast them to best erradicate corroded metal, after that sanding them back with finer grades of paper. If you are looking to keep the poished lip i would suggest finishing in 1200-1500 and laquer it to help stop future corrosion problems. Also helps to keep them looking fresh! You can get a sand blasting kit pretty cheap from screwfix for a d.i.y job. Easy to do, just take your time and try to keep blasting material and sand paper as fine as poss for each process. Aerosol primer will tend to only fill 240 grade scratch marks and finer. Hope that helps a little? Mate thank you soo much that helps alot. Off to buy a sand blaster Link to comment Share on other sites More sharing options...
Dnk Posted August 29, 2013 Share Posted August 29, 2013 I would personally have them chemi stripped in phosphoric acid if there is lacquer or paint on them, this is simply washed off in water to neutralise it. After this i would have them media blasted and then get the lips polished properly by a pro polisher who at the same time as polishing them will linish out any pitting in the aluminium as long as its not too deep and powder coat the centres, if that's the look your after. I spent along time on my lips prepping them by hand which to be honest i should of just let the polisher do I would use something like tiger seal for the sealer. I did my 3 piece Equips a couple of times, once with polished lips and powder coated centres and then powder coated all Black. Link to comment Share on other sites More sharing options...
Ian C Posted August 29, 2013 Share Posted August 29, 2013 I would throw them in the bin and get some 1-piece alloys that are lacquer coated and relax knowing you won't have a constant nightmare of corrosion and deflating tyres ruining your Supra fun Yes that's the voice of experience Link to comment Share on other sites More sharing options...
naybad Posted August 29, 2013 Share Posted August 29, 2013 I would throw them in the bin and get some 1-piece alloys that are lacquer coated and relax knowing you won't have a constant nightmare of corrosion and deflating tyres ruining your Supra fun Yes that's the voice of experience I’m going for new wheels next year going to save up for a set of compomotives or something like that. Craig Link to comment Share on other sites More sharing options...
Dnk Posted August 29, 2013 Share Posted August 29, 2013 Didn't have any issues with mine but then i powder coated all 3 pieces in the end as i couldn't be arsed with polishing the lips. Link to comment Share on other sites More sharing options...
T14PPA Posted August 29, 2013 Author Share Posted August 29, 2013 I would personally have them chemi stripped in phosphoric acid if there is lacquer or paint on them, this is simply washed off in water to neutralise it. After this i would have them media blasted and then get the lips polished properly by a pro polisher who at the same time as polishing them will linish out any pitting in the aluminium as long as its not too deep and powder coat the centres, if that's the look your after. I spent along time on my lips prepping them by hand which to be honest i should of just let the polisher do I would use something like tiger seal for the sealer. I did my 3 piece Equips a couple of times, once with polished lips and powder coated centres and then powder coated all Black. Thanks i think i will end up giving them to a place to polish. Shall i laquer after they have been polished? Link to comment Share on other sites More sharing options...
T14PPA Posted August 29, 2013 Author Share Posted August 29, 2013 I would throw them in the bin and get some 1-piece alloys that are lacquer coated and relax knowing you won't have a constant nightmare of corrosion and deflating tyres ruining your Supra fun Yes that's the voice of experience Looooool not the news i wanted to hear. But i can imagine the problems lol. I only payed £300 for them though Link to comment Share on other sites More sharing options...
Dnk Posted August 29, 2013 Share Posted August 29, 2013 Thanks i think i will end up giving them to a place to polish. Shall i laquer after they have been polished? I personally wouldn't leave them just polished as its a never ending job trying to keep them looking good. Link to comment Share on other sites More sharing options...
T14PPA Posted August 29, 2013 Author Share Posted August 29, 2013 I personally wouldn't leave them just polished as its a never ending job trying to keep them looking good. Are you saying to laquer them or paint them? Link to comment Share on other sites More sharing options...
Guest SL1D3Y Posted August 30, 2013 Share Posted August 30, 2013 You need to be careful, as once there highly polished the clear wont stick and just peel off giving you more work! Powder coating is great as it gives a nice even cover over the entire surface. Will be the best bet to keep away the corrosion. If you like the polished lip and have it done proffessionally ask them about an etching clear coat. Its not the cheapest option, but will last as the etch would help it stick to the bare metal. It really comes down to what you want to spend and how you want themm to look. You can buy a really fine silver (wheel chrome) which you could paint the lip in to give the effect? Mipa do a good one, use a bblack or silver base and finish with clear coat. But you cant sand between coats as it shows up all scratch marks if you go courser than 3000 grit. Link to comment Share on other sites More sharing options...
