Guest damian Posted August 27, 2013 Share Posted August 27, 2013 Am doing a 1jz into an BMWe30 install using the 154 gearbox and am having trouble getting the "right" clutch fork. The support bar arrived today but is about 1mm too wide to fit the supplied fork.I have done a lot of searching on the net to see how many types there are but struggling to get a definitive answer.I could adapt the support hook to work but not sure if this will effect the clutch action at all. to be honest im a bit doubtful the supplied fork is the correct item i need.So can anyone tell me exactly what i need to install to make the clutch work as it should,, Quote Link to comment Share on other sites More sharing options...
