crank pulley
Guest aspire
Guest aspire
had a search, but nothing highlighted.
Question 1) is the crank pulley same for NA & TT
Question 2) if i was to purchase an uprated crank dampener eg, TITAN i need a longer belt, this is being listed as the jza80 gte, will this still be fitment for the NA? reason being im building up a decent NA-T.
Guest aspire
[ATTACH]174279[/ATTACH]
ATI's hole diameter was 34.95mm
Stock is 35.04
The ATI was an interference fit. They had right trouble getting it off. It's shredded 3 aux belts while it was on the car in my ownership of a bit over a year
this is the one i was going to buy, i cant believe for the money you had such issues with it, did the dampener pulley sit proud of the other pulleys causing belt to not run true??
It's a 6 speed. I took it to the garage reporting that it was shredding belts. Initially we thaught it was the AC as it started after it was refitted but the alignment and everything was checked on them and they were all fine. Including the ATI crank pulley. They couldn't explain it so decided to pull it off to double check it. But it wouldn't move.
This has been a interesting read, because I have been thinking about replacing mine.
So a OEM one or Whifbtiz crank pulley can hold big BHP? For example If I was going down a single turbo route 650BHP would be fine
Oem yes. Whifbitz I don't know. It's a blueprint copy though.
The ati crank pulley instructions say that you may have to open out the pulley to get the right tolerance. It was to do with them being able to work with aftermarket cranks that weren't the exact size of oem.
The belt size needed is a 6pk1969 for ati
Std size 6pk1936
Std pulley without aircon is 1865 according to someone on here
So I guess correct me if I'm wrong it would be 1898 for ati with aircon removed. Think gates does a 6pk1900.
That's just for anyone who does a search
Std size 6pk1936
That is correct I use a pk1865 for std pulley no aircon, I searched with no luck on belt size for an ati so by the looks of it 1990 should be the one for me when I change pulleys.
Thanks for the info :thumbs:
Just make sure you hone out the inside of the ati centre. It's states the measurements in the instruction manual
