antno Posted August 26, 2013 Share Posted August 26, 2013 Hello I've recently bought a hks evc 5 black edition or 6 and I was wondering where to splice into the wiring to get a pick up for rpm and throttle position. I take it its probably the tach wire of that makes its way from the igniter to the dash but not sure about throttle position. Does anyone know if I can splice into a wire behind the dials or will they both be from the ecu. I also have hks f con silver which from memory has the usual patch loom but also the ability to connect I suspect things like this from hks. If anyone could shine some light that would be helpful. Cheers antno Quote Link to comment Share on other sites More sharing options...
drew 007 Posted August 26, 2013 Share Posted August 26, 2013 Are they blue and white cables buddy? Quote Link to comment Share on other sites More sharing options...
antno Posted August 26, 2013 Author Share Posted August 26, 2013 Are they blue and white cables buddy? Yes pal Quote Link to comment Share on other sites More sharing options...
drew 007 Posted August 26, 2013 Share Posted August 26, 2013 The blue is the throttle input signal and the white is the speed rpm signal i spliced mine at the ecu buddy. Quote Link to comment Share on other sites More sharing options...
antno Posted August 26, 2013 Author Share Posted August 26, 2013 The blue is the throttle input signal and the white is the speed rpm signal i spliced mine at the ecu buddy. Cheers pal you don't know what PIN numbers by any chance do you? Quote Link to comment Share on other sites More sharing options...
