supra_ufo Posted August 24, 2013 Share Posted August 24, 2013 Just as I was preparing my car up for BPU/cleaning for Monday. I noticed a coolant leak from under the car.. Thanks to Iky we took a load of pipes off and worked out that it was coming from the pipes picture below... They have been corroded heavily and there is a hole under the pipe. Does anyone know if these pipes come as part of a new heater matrix unit? I wont be able to make Monday in my car :-( Link to comment Share on other sites More sharing options...
ScottC Posted August 24, 2013 Share Posted August 24, 2013 (edited) Can't you just bypass the heater matrix, it's going to be hot on monday so you won't need it? Boom! back in the game:D Edited August 24, 2013 by ScottC (see edit history) Link to comment Share on other sites More sharing options...
marbleapple Posted August 24, 2013 Share Posted August 24, 2013 Can't you just bypass the heater matrix, it's going to be hot on monday so you won't need it? Boom! back in the game:D Agreed! Link to comment Share on other sites More sharing options...
supra_ufo Posted August 24, 2013 Author Share Posted August 24, 2013 I am coming with Iky in his supra. I could bypass it....which pipes do I need to cross. Means no ac either Link to comment Share on other sites More sharing options...
Abz Posted August 24, 2013 Share Posted August 24, 2013 I am coming with Iky in his supra. I could bypass it....which pipes do I need to cross. Means no ac either Open the bloody window! C'mon man! I'll keep a tissue here to dry you down Link to comment Share on other sites More sharing options...
ScottC Posted August 24, 2013 Share Posted August 24, 2013 Just join the two hoses going to the matrix together. Air con has nothing to do with the matrix. Link to comment Share on other sites More sharing options...
supra_ufo Posted August 24, 2013 Author Share Posted August 24, 2013 I'm still coming either in mine or Ikys Back to the original question are those two pipes part of the matrix? Link to comment Share on other sites More sharing options...
mellonman Posted August 24, 2013 Share Posted August 24, 2013 Just join the two hoses going to the matrix together. Air con has nothing to do with the matrix. I had my HEATER matrix fail before and made a pipe to bypass that lives in my boot, all you have to do is join the rubber pipes together that go in the end of them pipes sticking out No they are not part ofthe heater matrix they just join to it, All you will loose is the heat from the heater Link to comment Share on other sites More sharing options...
supra_ufo Posted August 24, 2013 Author Share Posted August 24, 2013 in the long run how do I replace those pipes as its that with the hole... I can live without the heater as Monday looks nice Link to comment Share on other sites More sharing options...
mellonman Posted August 24, 2013 Share Posted August 24, 2013 I cant remeber if you can get to them from the engine bay or not but if you cant, them best/easiest would be get a silicon pipe that can cover the hole depending on position Link to comment Share on other sites More sharing options...
Dnk Posted August 24, 2013 Share Posted August 24, 2013 I'm still coming either in mine or Ikys Back to the original question are those two pipes part of the matrix? Yes. Just put a loop connecting the inlet and outlet matrix feed pipes together till you replace the matrix. Page AC-24 Page AC-51 Have good diagrams of the heater matrix showing the pipes etcAC.pdf Link to comment Share on other sites More sharing options...
dude Posted August 24, 2013 Share Posted August 24, 2013 Dash out im afraid budget for a day and a half maybe 2 if you havent done it before. You may as well change the matrix while your in there. Link to comment Share on other sites More sharing options...
ScottC Posted August 24, 2013 Share Posted August 24, 2013 Yes. Just put a loop connecting the inlet and outlet matrix feed pipes together till you replace the matrix. Page AC-24 Page AC-51 Have good diagrams of the heater matrix showing the pipes etc Dunk, where do you find these pdf's I can never find them? Link to comment Share on other sites More sharing options...
Dnk Posted August 24, 2013 Share Posted August 24, 2013 Dunk, where do you find these pdf's I can never find them? Top secret Give me your email address and i'll send you what i have which is pretty much all of them Link to comment Share on other sites More sharing options...
dude Posted August 24, 2013 Share Posted August 24, 2013 I have all of them as well;) Link to comment Share on other sites More sharing options...
Homer Posted August 24, 2013 Share Posted August 24, 2013 To replace those pipes, I'm pretty certain the heater matrix has to come out, like dude said. It's a fair bit of work, but it's not as bad as it appears. I did mine in an afternoon, took about 5 hours. Link to comment Share on other sites More sharing options...
dude Posted August 24, 2013 Share Posted August 24, 2013 Yeah so a day and a half with beer stops !!!! Its a horrible job and a lot depends on the state of the wiring behind the dash, ie stereo install etc Link to comment Share on other sites More sharing options...
supra_ufo Posted August 25, 2013 Author Share Posted August 25, 2013 This does the trick Its something I bought from B&Q 15MM flexible copper pipe... Taken the car for a harsh drive and it seems to be good... Should be there in mine tomorrow, but I haven't had the time to install my refurbed head lights or polish the car :-/ Link to comment Share on other sites More sharing options...
marbleapple Posted August 25, 2013 Share Posted August 25, 2013 Don't worry about that pal. My paintwork is awful at the moment. At worst case you'll be in good company! Link to comment Share on other sites More sharing options...
supra_ufo Posted August 25, 2013 Author Share Posted August 25, 2013 Don't worry about that pal. My paintwork is awful at the moment. At worst case you'll be in good company! Im not lifting my bonnet either im just going to tell people I have an N/A Link to comment Share on other sites More sharing options...
