Jonnybravo2667 Posted August 24, 2013 Share Posted August 24, 2013 Hi all i have j-spec brakes and i have just replaced the rear calipers with reconditioned ones and i have a rattle from the pads, i know its the inside pad thats rattling because i can move it very slightly, the pads are new also, what can i do to fix this? is there a anti rattle spring kit or something i can get? Many thanks in advance John Link to comment Share on other sites More sharing options...
Guest Benny9 Posted August 24, 2013 Share Posted August 24, 2013 Hi Yes it should have a brake pad retainer/anti rattle clip, can you check if it's there? I had the same thing on mine, it was coming from the front drivers side and after checking realised there was no retainer clip holding them down, I could only find the part from Toyota who wanted to charge £40-60!!!! if I remember right. if you still have you're old calipers/brakes see if its still got the clip to reuse a lot cheaper Link to comment Share on other sites More sharing options...
