Single turbo on 2jz/ge
cooin
All the mechanics on this none turbo to turbo project is done and working fine , Problem is engine management , have tried uni chip q but it couldnt get around the issue of the std Map sensor tripping the engine management light and stopping progress , is this going to be the case with all pigy backs ? or is there a pigy back with its own Map sensor that could go around this issue ? cheers all
Uni chip?
Is that a piggy back or chip?
Emanage/ ultimate by greedy is used by many with no problems.
Do a search for NA-T on here and all the info will be found mate
Yes, it's a piggy pack, everything set up already, full map done, only problem is stand map sensor can not read positive boost putting stand ecu fault code light on, not allowing progress with uni chip.
Uni chip?
