Guest Roger NE Posted August 22, 2013 Share Posted August 22, 2013 Has anyone fitted these American Exhaust Headers? http://www.ebay.co.uk/itm/STAINLESS-RACING-HEADER-MANIFOLD-EXHAUST-93-98-TOYOTA-SUPRA-MK4-3-0L-NA-2JZ-GE-/400504360233?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d3feb8d29 The question is . . . do they foul the Steering Column/Coupling on a RHD car? Link to comment Share on other sites More sharing options...
Nic Posted August 22, 2013 Share Posted August 22, 2013 Looks like a copy of the Xerd header, these were designed to fit a US LHD Supra and do fowl the steering column. It also has threaded oxygen sensor bosses, which will not fit the stock 2 bolt flanged sensors. Recent thread on the same subject http://www.mkivsupra.net/vbb/showthread.php?294624-N-A-decat-rubbing-on-steering-column-safe-to-use/page2&highlight=xerd Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 22, 2013 Share Posted August 22, 2013 Well just because it looks SIMILAR to the one you had doesn't mean it WILL foul the steering column ! It could easily be 10mm further in I have e-mailed them to ask, but they probably don't know ! That's why I was hoping someone on here has bought one - they do look rather good value. Also, screw-in O2 sensors are fine - all the Aftermarket ones are screw-in, so saves using an adapter plate. (Would never buy one from Toyota !) Link to comment Share on other sites More sharing options...
Al Massey Posted August 22, 2013 Share Posted August 22, 2013 (edited) Well just because it looks SIMILAR to the one you had doesn't mean it WILL foul the steering column ! It could easily be 10mm further in I have e-mailed them to ask, but they probably don't know ! That's why I was hoping someone on here has bought one - they do look rather good value. Also, screw-in O2 sensors are fine - all the Aftermarket ones are screw-in, so saves using an adapter plate. (Would never buy one from Toyota !) No need to be rude! And if you knew who you were talking to you wouldn't be like that. 1 Nic knows his stuff and if you do a search on here or google you will find any US header does fowl the steering. And 2, which is probably important for you to know. Nic designed, tested and made his own headers that were for sale and sold quite a few to many members, and are sought after items. Again do a search for Nic's manifold and your eyes will be opened. So if he says it looks like a specific brand then it probably is. Yes it looks well built, in a picture but that doesn't mean it won't fowl. And I've hardly seen any screw in type 02 sensors, and I also may mine from the states for a fraction of the cost. Edited August 22, 2013 by Al Massey (see edit history) Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 22, 2013 Share Posted August 22, 2013 (edited) I'm sorry, but I don't believe I said anything rude! I was merely stating an opinion . . . . that this PARTICULAR one MIGHT be OK. What was rude about that? And if I didn't SUSPECT that it might fowl the Steering Column I wouldn't have started this thread, asking if anyone had bought this particular brand. (I did do a Search about Headers, but found nothing relevant) And all the aftermarket O2 Sensors (for different cars, including my Supra) I have bought over the past 14 years have been the screw-in type Edited August 22, 2013 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
trebor69 Posted August 22, 2013 Share Posted August 22, 2013 If it's for a LHD then you will need to beat the 2nd downpipe into collector down to half the size for it not to foul the column , o2 sensors are available from ebay but its the wire you use to join the sensors to your plugs that must be steel core not copper. Link to comment Share on other sites More sharing options...
skippyboyo1 Posted August 22, 2013 Share Posted August 22, 2013 I binned my 02 sensor and blanked the holes! 5 years with zero problems! Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 22, 2013 Share Posted August 22, 2013 Surely the O2 Sensors fine tune the fuelling? Certainly when my exhaust emissions went up it was because I needed a new O2 Sensor Link to comment Share on other sites More sharing options...
Stevo Posted August 22, 2013 Share Posted August 22, 2013 Perhaps rethink your use of Block Caps and the exclamation mark in your first response to Nic... Block Caps is considered as 'shouting'. Link to comment Share on other sites More sharing options...
skippyboyo1 Posted August 22, 2013 Share Posted August 22, 2013 Surely the O2 Sensors fine tune the fuelling? Certainly when my exhaust emissions went up it was because I needed a new O2 Sensor Mine does 14.3 quarters all day so I don't care Link to comment Share on other sites More sharing options...
supra joe Posted August 22, 2013 Share Posted August 22, 2013 Leave him alone, he's a Geordie.... We're all mentally retarded. Link to comment Share on other sites More sharing options...
safcdixon Posted August 22, 2013 Share Posted August 22, 2013 Leave him alone, he's a Geordie.... We're all mentally retarded. Dont tempt me Joe I have a million lines to use pmsl Link to comment Share on other sites More sharing options...
Stevo Posted August 22, 2013 Share Posted August 22, 2013 Me too, ready for what you might bring Marc.... Link to comment Share on other sites More sharing options...
supra joe Posted August 22, 2013 Share Posted August 22, 2013 Haha go for it, just remember I hate football and I like punching people..... LOTS hahaha. Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 22, 2013 Share Posted August 22, 2013 (edited) Perhaps rethink your use of Block Caps and the exclamation mark in your first response to Nic... Block Caps is considered as 'shouting'. Well I use Block capitals to stress a particular word . . . and exclamation marks to make light of a comment . . . either way I don't think I was being rude And even more so, no rudeness was intended to Nic or anyone else ! Edited August 22, 2013 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
safcdixon Posted August 22, 2013 Share Posted August 22, 2013 Me too, ready for what you might bring Marc.... You start stevo, i dont wanna go into early with dog raping jibes just yet Haha go for it, just remember I hate football and I like punching people..... LOTS hahaha. Now now Joe! no need for the aggression, do you need a hug? Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 23, 2013 Share Posted August 23, 2013 Just heard back from the US company that make those Headers . . . . . they have said that unfortunately they DO interfere with the Steering Column, so can't be fitted to a RHD car (was actually quite surprised that they were aware!) So that confirms what Nic thought . . . . I just wanted to make sure from someone that knew these actual headers. Link to comment Share on other sites More sharing options...
Al Massey Posted August 23, 2013 Share Posted August 23, 2013 So that confirms what Nic already knew and tried to tell me Fixed for you mate Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 23, 2013 Share Posted August 23, 2013 LOL ! No . . . what Nic actually said was these LOOKED LIKE another set of headers that do foul the Steering Column That's why I replied with what I did . . . I wanted to know if anyone had tried this particular make! Link to comment Share on other sites More sharing options...
Al Massey Posted August 23, 2013 Share Posted August 23, 2013 LOL ! No . . . what Nic actually said was these LOOKED LIKE another set of headers that do foul the Steering Column That's why I replied with what I did . . . I wanted to know if anyone had tried this particular make! Jeez CALM DOWN lol Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 23, 2013 Share Posted August 23, 2013 Jeez CALM DOWN lol I wasn't the one getting worked up ! I'm just explaining/defending myself as I was accused of being rude ! Link to comment Share on other sites More sharing options...
Guest aspire Posted August 23, 2013 Share Posted August 23, 2013 I wasn't the one getting worked up ! I'm just explaining/defending myself as I was accused of being rude ! i can see they are going to have fun with you here, Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 23, 2013 Share Posted August 23, 2013 (edited) Getting back on topic . . . . . . I guess getting a cheap set of headers isn't a viable option Can someone please clarify for me . . . . does an original Exhaust on the N/A Mk4 Supra consist of the two separate Manifolds, each with the 3 pipes going into one, with a flange on the end . . . and bolted onto the LH one is a short pipe going into the first Cat, and the RH one has a flexi coupling that then goes into the same Cat? (ie just ONE Cat, not one on each downpipe?) And if that's the case, is there actually a JOIN in each of the pipes before they go into the Cat, or does the Cat come with those pipes sticking out the top? (can't see in photos very clearly - if there's a join just before the Cat it must be sleeved and clamped, as there are no flanges) Did any cars come as stock WITHOUT the first Cat(s) on the downpipes? Edited August 23, 2013 by Roger NE (see edit history) Link to comment Share on other sites More sharing options...
Al Massey Posted August 23, 2013 Share Posted August 23, 2013 i can see they are going to have fun with you here, Oh yes Getting back on topic . . . . . . I guess getting a cheap set of headers isn't a viable option Can someone please clarify for me . . . . does an original Exhaust on the N/A Mk4 Supra consist of the two separate Manifolds, each with the 3 pipes going into one, with a flange on the end . . . and bolted onto the LH one is a short pipe going into the first Cat, and the RH one has a flexi coupling that then goes into the same Cat? (ie just ONE Cat, not one on each downpipe?) And if that's the case, is there actually a JOIN in each of the pipes before they go into the Cat, or does the Cat come with those pipes sticking out the top? (can't see in photos very clearly - if there's a join just before the Cat it must be sleeved and clamped, as there are no flanges) Did any cars come as stock WITHOUT the first Cat(s) on the downpipes? Two separate manifolds. The Cat has two entry holes for the manifolds and one exit hole for the exhaust then to another cat. And no, came with two cats. No if you search for Nic's manifold you will see all the work that went in and why it is a sought after bit of kit. I had an autobahn88 manifold which just sold. There is another manifold in the for sale section. You will also see threads of a few different manifolds. Now a left hand drive header will fit, and most likely fouls the steering column but after some heating and bashing it will clear. There are a few that have been modified well. Link to comment Share on other sites More sharing options...
Guest Roger NE Posted August 23, 2013 Share Posted August 23, 2013 Yes I know they came with a SECOND Cat under the car . . . . . So you're confirming the Supra only ever has ONE cat on the downpipes? (I've seen some 2JZ-GE engines with a separate Cat in EACH downpipe) So as I described before, do those two pipes that bolt onto the flanges on each of the Manifolds go STRAIGHT into the single Cat? (ie without a join?) Link to comment Share on other sites More sharing options...
