hackin_n_bashin Posted August 21, 2013 Share Posted August 21, 2013 Hey guys, Looking to swap the guys around between an auto TT LSD and an NA manual open diff to create an NA LSD. Can someone help with regards to the parts and numbers I need, like the ring gear bolts and any seals please. Adam. Link to comment Share on other sites More sharing options...
Pulley Posted August 21, 2013 Share Posted August 21, 2013 I'll try n find the part numbers for the bolts I did the same myself I also made up some shims to adjust the backlash, so I I can find them your welcome to them Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 21, 2013 Author Share Posted August 21, 2013 Cheers pulley, that's ace of you. Did you replace any seals? Link to comment Share on other sites More sharing options...
Josh42 Posted August 21, 2013 Share Posted August 21, 2013 I know it's not much of a help Adam, but I have a brand new deflector for a NA Diff that your welcome to if your refreshing everything during your hybridisation:) Link to comment Share on other sites More sharing options...
Pulley Posted August 21, 2013 Share Posted August 21, 2013 As it happened my seals were all good and I'd recently replaced output bearings I used the na casing with its pinion and didn't actually need to shim or adjust Just swapped over diff cores I've done a few and tbh used the same crown bolts with new thread lock and is fine Decent socket and break bar needed lol Link to comment Share on other sites More sharing options...
Pulley Posted August 21, 2013 Share Posted August 21, 2013 Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted August 21, 2013 Author Share Posted August 21, 2013 Spot on mate, thanks very much. Link to comment Share on other sites More sharing options...
Jellybean Posted August 22, 2013 Share Posted August 22, 2013 OEM Part Numbers http://www.toyodiy.com/parts/ Link to comment Share on other sites More sharing options...
