al02uk Posted August 21, 2013 Share Posted August 21, 2013 Evening all, I've been away for a while after I sold my N/A supra. I also sold my Subaru as I decided I was going to be sensible. I spotted this UK TT Supra in auto trader and managed to haggle the guy down to £3250. It has full Toyota service history and loads of documentation, no little bits missing and all the electrics work. The engine seems pretty solid. The bad bits are: bits of rust near the front window (I think a chip guy could sort it out), there is a noise which comes from the O/S/F wheel when you turn the steering wheel to the right when stationary, its fine when driving, any ideas on this issue will be much appreciated. I'm not keen on the interior colour. I think I did ok, I know here aren't many UK Supras around, so I thought I'd give this a go. What do you think? Andy Link to comment Share on other sites More sharing options...
Dnk Posted August 21, 2013 Share Posted August 21, 2013 (edited) What mileage has it done ? £3250 for a straight uk tt is a bargin unless its been to the moon and back Regarding the noise i'd jack that corner up and do a few simple checks, spin the wheel and check wheel bearing for noise and play and check lower arm bushes and suspension bolts etc . Can you describe the noise ? Edited August 21, 2013 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
supra_ufo Posted August 21, 2013 Share Posted August 21, 2013 bargain! looks like a good example Link to comment Share on other sites More sharing options...
clay Posted August 21, 2013 Share Posted August 21, 2013 Hi mate looks pretty good in the pics. whats the mileage.? Link to comment Share on other sites More sharing options...
skippyboyo1 Posted August 21, 2013 Share Posted August 21, 2013 Has it got r2d2 in the boot! Link to comment Share on other sites More sharing options...
Homer Posted August 21, 2013 Share Posted August 21, 2013 Nice find that and a great price, congrats! Link to comment Share on other sites More sharing options...
MAD-MAX Posted August 21, 2013 Share Posted August 21, 2013 just over 200k i think - I remember seeing it advertised... Looks well tho Link to comment Share on other sites More sharing options...
Tsia Posted August 21, 2013 Share Posted August 21, 2013 Haha, bought from the same place I got mine! Check out the avatar, look familiar? Link to comment Share on other sites More sharing options...
al02uk Posted August 21, 2013 Author Share Posted August 21, 2013 What mileage has it done ? £3250 for a straight uk tt is a bargin unless its been to the moon and back Yeah, its done a lot of mileage, around 200k. Didn't really put me off though as my N/A had done 150k and I couldn't fault it. The idea with this is to have someone look over the engine and see how tired it is and perhaps rebuild the bottom end. I have around 5k to spend on it. My other half is in USA so she may have to send me a new bottom end as a "gift" to avoid import tax (if that's possible of course) Link to comment Share on other sites More sharing options...
al02uk Posted August 21, 2013 Author Share Posted August 21, 2013 Regarding the noise i'd jack that corner up and do a few simple checks, spin the wheel and check wheel bearing for noise and play and check lower arm bushes and suspension bolts etc . Can you describe the noise ? Sorry Dnk, I didn't see this. The noise sounds like something I would expect to hear if perhaps a calliper had seized or I had my foot on the brakes and I was trying to move, if that makes sense? its like a high pitched metallic sound. It only happens when stationary or at very low speed, like 10mph. above 10mph it stops. I'll have a look like you suggested to see if there's anything obvious. Thanks for the advise. Link to comment Share on other sites More sharing options...
Pete Posted August 21, 2013 Share Posted August 21, 2013 I thought at first glance on the first photo you'd done it in black and white and left just spot colour in for the indicators and plate. Strange but true. Link to comment Share on other sites More sharing options...
Dnk Posted August 22, 2013 Share Posted August 22, 2013 (edited) Sorry Dnk, I didn't see this. The noise sounds like something I would expect to hear if perhaps a calliper had seized or I had my foot on the brakes and I was trying to move, if that makes sense? its like a high pitched metallic sound. It only happens when stationary or at very low speed, like 10mph. above 10mph it stops. I'll have a look like you suggested to see if there's anything obvious. Thanks for the advise. Have a close look at the brakes then, if they're the originals and not been refurbed they will be on the verge if not already failing due to the outer piston dirt seals splitting or getting holes in them which will let moisture and dirt get down the side of the pistons causing them to seize. With the age and mileage on this car i'd be going over it very thoroughly and go through the bills receipts etc to see whats been changed on it over the years. Edited August 22, 2013 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
marc_p Posted August 22, 2013 Share Posted August 22, 2013 Thats a serious bargain for a TT!!!! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted August 22, 2013 Share Posted August 22, 2013 I chatted to the owner of this before that dealer bought it… Needs new turbo's/ a refurb was the conclusion I drew from what he told me about it, and valve stem seals need doing. £500 for the VSS and then 900-1000 for a turbo refurb.. Basically throw 2K plus the paintwork at it and you'll have a nice car. Full Toyota service history, so I would have thought it's been ran on good oil it's whole life, the bottom end should be ok at stock power, I wouldn't push it too hard though. Another point is; That dealer is obviously scouting on here and abusing the PM System too buy Cars…. Needs to be stopped now we know who it is... Link to comment Share on other sites More sharing options...
Dnk Posted August 22, 2013 Share Posted August 22, 2013 With the mileage its done and age i hope you find lots of receipts for replaced parts or it could turn into a money pit rather than the bargin it first seems. All the best with it though - - - Updated - - - I chatted to the owner of this before that dealer bought it… Needs new turbo's/ a refurb was the conclusion I drew from what he told me about it, and valve stem seals need doing. £500 for the VSS and then 900-1000 for a turbo refurb.. Basically throw 2K plus the paintwork at it and you'll have a nice car. Full Toyota service history, so I would have thought it's been ran on good oil it's whole life, the bottom end should be ok at stock power, I wouldn't push it too hard though. Another point is; That dealer is obviously scouting on here and abusing the PM System too buy Cars…. Needs to be stopped now we know who it is... Who ? Link to comment Share on other sites More sharing options...
Fitz Posted August 22, 2013 Share Posted August 22, 2013 Yeah, the price has gone up through the dealer from when it was inquired about from the original seller. Link to comment Share on other sites More sharing options...
Jord Posted August 22, 2013 Share Posted August 22, 2013 £3250 for a UK is ridiculously low, nice find. A lot of miles though. Link to comment Share on other sites More sharing options...
al02uk Posted August 22, 2013 Author Share Posted August 22, 2013 I could do the valve stem seals myself using the guide on here, although there doesn't seem to be any sign that they need replacing. Fefurbing the turbo's seems plausible given the mileage. There are a load of receipts from the Toyota garage in Bracknell, this includes both rear shocks replaced, all brake hoses, turbo coolant pipes and gaskets etc. I think its been well looked after, its had 28 dealer services. To be honest, I expect it to be a bit of a money pit. I put 12k into the engine alone on my Subaru and only ended up getting 10k for the whole car. I don't want to go that crazy mind. Link to comment Share on other sites More sharing options...
Dnk Posted August 22, 2013 Share Posted August 22, 2013 (edited) Just as a heads up regarding parts i had to replace and problems i had on my uk spec a few years ago, it had done around 110k. Radiator & cap, thermostat, heater matrix, diff cooler rad, valve stem seals, cam cover seals, heater hoses, crank pulley, seizing calipers due to outer dirt seals failing, seized eccentric adjusters on lower suspension arms, main steel brake lines corrode badly up around the rear axle. shocks failed on rear, engine mounts, smic intercooler fins crumbled to bits even though it looked ok, a/c rad Edited August 22, 2013 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
al02uk Posted August 22, 2013 Author Share Posted August 22, 2013 Well I've just got back from having the wheels off, I checked everything at it all seemed fine. Checked brake lines too, all ok. I put the wheels back on and the noise has vanished? so not really sure what the cause was. I took it for a test run and everything seems to be ok. It might just be because it has been sat. The disks and pads do need changing on the front though. And thanks for the heads up, much appreciated. Link to comment Share on other sites More sharing options...
