Murf2j Posted August 21, 2013 Share Posted August 21, 2013 Hi guys, Thinking if buying some alloys for my supra tomorow, fitment is 18x9.5j et26 on all 4 corners, how will this scope up for sitting in the arches or hanging out? Any help will be appreciated Thanks Link to comment Share on other sites More sharing options...
Scooter Posted August 21, 2013 Share Posted August 21, 2013 I think you will have issues on the front at least probably the rear too depending on the tyres you fit. The fronts will be over 4cm further out than stock wheels. Link to comment Share on other sites More sharing options...
Josh42 Posted August 21, 2013 Share Posted August 21, 2013 I run 9.5J ET30 fronts with 235/40/18 FK452, with 40mm Tein springs. I wouldn't want to go for much more of an aggressive offset to be fair! Link to comment Share on other sites More sharing options...
boomstick Posted August 22, 2013 Share Posted August 22, 2013 I think you will have issues on the front at least probably the rear too depending on the tyres you fit. The fronts will be over 4cm further out than stock wheels. Also, its a 'no go' if your car is lowered! Google 'wheel offset', there are really good calculators in the interweb! Link to comment Share on other sites More sharing options...
mattdavies Posted August 22, 2013 Share Posted August 22, 2013 I run 18x10 ET20 all round. Works out fine for me, arch work at the back and lowering springs on the front Link to comment Share on other sites More sharing options...
