Steve A Posted August 19, 2013 Share Posted August 19, 2013 Apologies for the terrible pic but im having some starting issues (car wont start full stop) and in having a look round ive found this plug which isnt connected to anything any ideas what it is? also could it be related ti my starting issue?. Its located near the fuse box and the cable its attached to runs to the top of the engine block. Quote Link to comment Share on other sites More sharing options...
Dave Posted August 19, 2013 Share Posted August 19, 2013 mines an n/a and i havent got that plug ,have you checked your main fuses the big ones . Quote Link to comment Share on other sites More sharing options...
keron Posted August 19, 2013 Share Posted August 19, 2013 Does it come out of the loom just there? The closest plugs I can think of are for the abs pump and ac switch a little dither back towards the bulkhead...but never seen that plug in that position ever Quote Link to comment Share on other sites More sharing options...
Steve A Posted August 19, 2013 Author Share Posted August 19, 2013 Mines Also an NA but a 93 Aerotop checked and all fusebox is connected that i can see and yes it does come out of the loom there. This is a pic front on with the battery out. Im assuming as nobody knows what it is its not going to be the reason car does not start Quote Link to comment Share on other sites More sharing options...
Homer Posted August 19, 2013 Share Posted August 19, 2013 I also have this plug on my NA 5spd (It was TT originally, but this is part of the NA engine loom). It's not used on my one either. Could it be one for the secondary fans that some cars came with? I think one is for the AC and maybe one for auto box cooler Quote Link to comment Share on other sites More sharing options...
ScottC Posted August 19, 2013 Share Posted August 19, 2013 I also have this plug on my NA 5spd (It was TT originally, but this is part of the NA engine loom). It's not used on my one either. Could it be one for the secondary fans that some cars came with? I think one is for the AC and maybe one for auto box cooler They both pop out of the loom under the passenger headlight. They are wired through two big relays under the headlight, and controlled by the stat in the rad, and the 4 pin aircon pressure switch found on TT's. Quote Link to comment Share on other sites More sharing options...
