supra_ufo Posted September 30, 2013 Author Share Posted September 30, 2013 I would say a leak, Have you put this into ttc and took it out for a blast to preasurise the system and then watched the egbv acuator arm or pulled a vac pipe off after 10 minutes to see if its still got preasure, this is the best way to check the hole sequential system for a leak, I have a spare preasure tank in the back on my van if you need it , there is also a vsv over there too Mellon when you said pressure tank here do you mean the thing I high lighted or something else mate? Link to comment Share on other sites More sharing options...
Gpro Posted September 30, 2013 Share Posted September 30, 2013 Mellon when you said pressure tank here do you mean the thing I high lighted or something else mate? the pressure tank is under the intake manifold. You can't really see it without taking the intake manifold off. If you have a small mirror it would help Link to comment Share on other sites More sharing options...
mellonman Posted October 1, 2013 Share Posted October 1, 2013 Mellon when you said pressure tank here do you mean the thing I high lighted or something else mate? the thing in the picture is the charcoal canister , i cant remember if that has a boost referance and is preasurised or not , but what i was talking about is the actual sequential preasure tank which is located inbetween the intake and block, you would have to take the intake pelum off to gain access to it , there is a tank and a vsv over there so also vac pipes , i do have one you can have with the vsv just give us a drink and cover postage if you want it but you still need to see or at least tell us when your in TTC and the big exhaust actuator opens this is sort of near the front near the fist turbo and goes to the exhaust down pipe, test it by setting to TTC driving try and get full boost tehn stop and pull the vac pipe off if you see it close then great its working , if you pull the pipe of and it does not move tehn you have a problem, question 1, did your actuator move ? yes = you may have a intercooler pipe off and loosing boost that way, NO= move onto question 2 question 2, did you get a release of air when you pulled the vac pipe off the actuator ? Yes = your actuator if shot/seezed, NO = you have a vac leak. now as we suspect the preasure tank as we can hear a leak in the vid you could simply get to the preasure tank vac pipe and give preasure from a foot pump or the likes of (with a gauge is a must ) pump until you get to 1 bar or 14psi and see if you hear a leak and loose preasure from your gauge reading , im at work so cant link in picture but i might be able to find so threads that you may have to look through Link to comment Share on other sites More sharing options...
mellonman Posted October 1, 2013 Share Posted October 1, 2013 (edited) http://www.mkiv.co.uk/vbb/showthread.php?35926-The-sequential-system post 1 picture 4 is the actuator post 1 picture 1 would be the route you would follow to find the the preasure tank vac feed ( you can follow this until you get to a point it would be easiest to get to) http://www.google.co.uk/imgres?imgurl=http://www.max-boost.co.uk/max-boost/images/supra/hotspot_locations/pressure_tank.gif&imgrefurl=http://www.max-boost.co.uk/max-boost/supra/turbo.htm&h=372&w=374&sz=12&tbnid=oGXUDp3HWeyxQM:&tbnh=90&tbnw=90&zoom=1&usg=__qC5U_u7YjcA1P0_EuLN1NKe4v3I=&docid=UyxYRAQqabJn8M&sa=X&ei=TnZKUovrAoOv7AbPhYDoBA&ved=0CE4Q9QEwAg preasure tank location http://www.google.co.uk/imgres?um=1&hl=en&biw=1229&bih=767&tbm=isch&tbnid=f6AuaU-q7tnxuM:&imgrefurl=http://www.imagejuicy.com/images/exotic-cars/t/toyota-supra-turbo/30/&docid=BcyxhByGl4Y-SM&imgurl=http://94supraturbos.synthasite.com/resources/2jzgte_vacuum.jpg&w=879&h=755&ei=fndKUrHhDoXR7AaXjICoDQ&zoom=1&iact=rc&page=1&tbnh=129&tbnw=150&start=0&ndsp=25&ved=1t:429,r:1,s:0,i:83&tx=73&ty=79 a easier vacuum diagram to follow Edited October 1, 2013 by mellonman (see edit history) Link to comment Share on other sites More sharing options...
supra_ufo Posted November 30, 2013 Author Share Posted November 30, 2013 Just replaced the VSV and stuck the car back into normal seqential mode and its boosting to 1.2BAR OMG the car is a monster, I think i prefer this to TTC The old VSV must of been working but not 100%, I would of thought it either works or doesn't, well goes to show it doesn't. http://www.internetwork.org.uk/mechanical/ttc/ttc02.jpg Link to comment Share on other sites More sharing options...
Mk4Gaz Posted November 30, 2013 Share Posted November 30, 2013 Thanks for posting this up mate, I too have a problem with the sequential mode, in that sometimes it'll work fine, other times it just won't boost over 0.5 bar and feels like the second turbo isn't coming online. I've put it into ttc mode, and it boosts hard to 1.2 bar, and that's how mine has stayed for a couple of months now. I want to go back to sequential, but wasn't sure how to check everything - with the info in this thread, it will be a great help. My top vsv checks out fine, according to the bgb and my multimeter readings - did yours? Link to comment Share on other sites More sharing options...
mellonman Posted December 1, 2013 Share Posted December 1, 2013 Thanks for posting this up mate, I too have a problem with the sequential mode, in that sometimes it'll work fine, other times it just won't boost over 0.5 bar and feels like the second turbo isn't coming online. I've put it into ttc mode, and it boosts hard to 1.2 bar, and that's how mine has stayed for a couple of months now. I want to go back to sequential, but wasn't sure how to check everything - with the info in this thread, it will be a great help. My top vsv checks out fine, according to the bgb and my multimeter readings - did yours? Yours sounds like the egbv sticking, if it happens take you foot off the throttle and slam it back down I bet it will boost correctly after Nice to see the update wish everyonedone done that , top stuff mate awsome cars at sequential bpu now be careful in the winter Link to comment Share on other sites More sharing options...
Mk4Gaz Posted December 1, 2013 Share Posted December 1, 2013 Yours sounds like the egbv sticking, if it happens take you foot off the throttle and slam it back down I bet it will boost correctly after Nice to see the update wish everyonedone done that , top stuff mate awsome cars at sequential bpu now be careful in the winter Funny you should say that, because that does actually happen! So, I just need to find out what an egbv is (exhaust gas bypass valve I guess) Thanks bud Link to comment Share on other sites More sharing options...
mellonman Posted December 1, 2013 Share Posted December 1, 2013 Funny you should say that, because that does actually happen! So, I just need to find out what an egbv is (exhaust gas bypass valve I guess) Thanks bud http://mkivsupra.net/vbb/showthread.php?35926-The-sequential-system Have read there mate Link to comment Share on other sites More sharing options...
supra_ufo Posted December 1, 2013 Author Share Posted December 1, 2013 I didnt know how to check with a multimeter, just replaced it. Well it annoys me that there are so many threads with issues and no one has updated the resolution! thanks for everyones help. Link to comment Share on other sites More sharing options...
Iky Posted December 1, 2013 Share Posted December 1, 2013 First time I've been in a bpu spec supra, The kickdown is pretty savage, It goes like sh1t off a shovel I can't wait to get mine sorted now. Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted December 1, 2013 Share Posted December 1, 2013 Just replaced the VSV and stuck the car back into normal seqential mode and its boosting to 1.2BAR OMG the car is a monster, I think i prefer this to TTC The old VSV must of been working but not 100%, I would of thought it either works or doesn't, well goes to show it doesn't. http://www.internetwork.org.uk/mechanical/ttc/ttc02.jpg glad to see your problem has been sorted. How did you change the vsv? is it labeled "IACV VSV" on the picture? Yours sounds like the egbv sticking, if it happens take you foot off the throttle and slam it back down I bet it will boost correctly after Nice to see the update wish everyonedone done that , top stuff mate awsome cars at sequential bpu now be careful in the winter Funny you should say that, because that does actually happen! So, I just need to find out what an egbv is (exhaust gas bypass valve I guess) Thanks bud http://mkivsupra.net/vbb/showthread.php?35926-The-sequential-system Have read there mate how do you remove the EGBV? is there a guide anywhere to remove? ive looked on search, but cant find thanks Link to comment Share on other sites More sharing options...
supra_ufo Posted December 2, 2013 Author Share Posted December 2, 2013 glad to see your problem has been sorted. How did you change the vsv? is it labeled "IACV VSV" on the picture? how do you remove the EGBV? is there a guide anywhere to remove? ive looked on search, but cant find thanks Yes thats the one, take the hoses off however be careful, as I pulled Iky's off last time and the plastic came off so gentley pry them off and lift at the same time. Its screwed down with a 10mm Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted December 2, 2013 Share Posted December 2, 2013 thanks, ive put her into ttc, so i don't believe the IACV VSV is the problem as the problem still exists. ill make my own thread. thanks anyways. Link to comment Share on other sites More sharing options...
