Mk4Gaz Posted August 17, 2013 Share Posted August 17, 2013 If a non specific fitting kit is used, ie fitted directly to the intercooler pipe, what do you do with the stock bov and its hoses? Link to comment Share on other sites More sharing options...
Scott Posted August 17, 2013 Share Posted August 17, 2013 If a non specific fitting kit is used, ie fitted directly to the intercooler pipe, what do you do with the stock bov and its hoses? Cover the inlet and the outlet, the actuation line still gets used to actuate it. Similar to fitting one of the kits, only you plug up both ends rather than just the 1 Link to comment Share on other sites More sharing options...
Mk4Gaz Posted August 17, 2013 Share Posted August 17, 2013 Cover the inlet and the outlet, the actuation line still gets used to actuate it. Similar to fitting one of the kits, only you plug up both ends rather than just the 1 Thanks for the explanation dude Link to comment Share on other sites More sharing options...
