2JZ-GE Engine
Guest Roger NE
Guest Roger NE
Might leave the plastic bit off it off if it looks OK then, if only to keep it looking similar ! (My 2JZ engine hasn't arrived yet, so haven't had a chance to play)
Generally, I must admit the Mk4 Engine looks MUCH tidier . . . I guess Toyota learned by their mistakes (one of the silliest things on the Mk3 is mounting the HT Coil on the LH Side, so the feed to the Distributor has to drape right across the engine!)
Edited by Roger NE (see edit history)
Guest Roger NE
Oh that's good . . . so I presume the Engine I'm expecting won't have it! Many thanks David
I always thought it silly that Toyota never sold the N/A Mk4 in the UK . . . . does anybody know how many have been imported?
