Need some rear speakers !!
Tyson
Well seen as one of my rear speakers has given up the ghost and they are discontinued I need some reasonably priced decent speakers that fit straight into the existing holders. Not looking for all singing and dancing earth shattering bass boxes just something I can listen to my tunes on :) Don't really want to spend more than 100 quid really and ideally be able to pick them up from somewhere like halfords as I would like them as soon as I can and no one is ever in at home so delivery is a nightmare !!
Thanks muchly !!
would be very interested which size fits the optional rear pods.....
I guess they produce a better sound because of their shape?
Correct. Also helps with bass ;)
Easiest way to see what will fit is to remove the speakers, and measure the distance between the screw holes. Then, when you go to get some new ones, measure up to see if they fit ;)
http://mkivsupra.net/vbb/showthread.php?140112-WARNING-15-year-old-brake-line-rotted-through&p=1807359&viewfull=1#post1807359 :)
Also, there was a hertz ones that fitted but were out of my budget range
I think there is max around 45mm depth for the magnet in the pods but still depends a lot on magnet size.
