Indiglo??
MarcusEJ
Marcus, the box you're talking about is the power inverter - yes you need it. If you try to wire the gauges directly to power, you'll blow them.
El glo are where the whole gauge illuminates - normally blue or green.
Reverse el glo, are where the gauge is typically black (like oem) and just the numerals/icons illuminate - again in blue or green
I was wondering if the person who bought Riches car would post up at some point. The dials are easy to fit dude, I have fitted a few, you CAN remove the needles, just take a photo so you now where your fuel is, then use two small tea spoons to ease them off, one on each side. That way you can get the old fascias off and the new ones in the perfect spot.
