Overfuelling/misfiring NA
Guest jvanovich
Guest jvanovich
Hi, i have a problem with my 1993 N/A mk4, it wets two spark plugs and the rest of them are smoked the engine doesnt work properly to keep him running i must rev and makes a lot of black smoke. What could be? I cant make a diagnose becouse in my country are only 2 supras mk4 registered and i cant find a jack to fit. Sorry for my bad english. Can anyone help me?
Edited by jvanovich (see edit history)
I'd start with the obvious parts first
What state is the distributor cap in (inside) ? are the ht leads in need of replacing ? the plugs ? are the injectors working correctly ?
Do a leak down/ compression test as well
Do the plugs that get wet work in the cylinders that don't get wet
Guest jvanovich
The distributor cap is ok no obvious problems, i ve tested the plugs and they are ok too and the injectors work like a dream. I will make the compression test and i will switch the plugs like you said and see what happens. Thanks!
Guest jvanovich
No i didn`t touch anything. I was drivig with almost 80km/h when the check engine got on and after that misfired a few times and it does like in the video above. I didn`t touch anything.
P.S Sometimes, before this problem, the check engine light got on and the car worked right and after a while (1 minute) the light turned off. I thought it was a sensor.
  • 2 weeks later...
Guest jvanovich
I changed the plugs, spark plugs and the air sensor from the air cleaner and now i think its ok, she runs in idle and no smoke. Still a little missfire appear once in a while.
  • 1 year later...
Guest jvanovich
It's a lot time that appear this yellow light , while i'm running with the car after some chilometer appear this yellow light but is stopped together with the red stop signal in the odometer.
the car goes like nothing is happened and if you try to go faster there are no problems. All seems ok. any bad changement in the car or strange noises from engine.
I have to have afraid of it? COuld someone give an opinion for experience? the model is 93 NA with whifbitz exhaust and hks induction kit. NO SWAP no other changements at the moment.
Could someone give me a link where to buy the connerctors?
thanks in advance.
Hi i had the same problem with mine. Now i have bigger problems but all started in the same way.
After a while the engine started to missfire. I cleaned the injectors and it worked again for a while and missfired again i took the injectors out again and i fitted them back no cleaning no nothing and it worked for a while again.I didnt used the car for a year not even started for a year. These days i started the car the idle was 2000 RPM missfires and is very noisy. I didnt had the cable too. i changed some parts.
I changed the air sensor, sparkplugs, spark distribuitor and today i changed those rubber rings fron the injectors. now the idle is at 1000 RPM still missfires and missfires are in the intake.
I tried the TE1 with E1 Thing to get a code but nothing happened :(
sorry for my english i am from Romania And sorry for posting in this threat.
