Guest jvanovich Posted August 14, 2013 Share Posted August 14, 2013 (edited) Hi, i have a problem with my 1993 N/A mk4, it wets two spark plugs and the rest of them are smoked the engine doesnt work properly to keep him running i must rev and makes a lot of black smoke. What could be? I cant make a diagnose becouse in my country are only 2 supras mk4 registered and i cant find a jack to fit. Sorry for my bad english. Can anyone help me? Edited August 14, 2013 by jvanovich (see edit history) Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 14, 2013 Share Posted August 14, 2013 (edited) I'd start with the obvious parts first What state is the distributor cap in (inside) ? are the ht leads in need of replacing ? the plugs ? are the injectors working correctly ? Do a leak down/ compression test as well Do the plugs that get wet work in the cylinders that don't get wet Edited August 14, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 14, 2013 Share Posted August 14, 2013 The distributor cap is ok no obvious problems, i ve tested the plugs and they are ok too and the injectors work like a dream. I will make the compression test and i will switch the plugs like you said and see what happens. Thanks! Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 14, 2013 Share Posted August 14, 2013 here is a video with my not working car and throws a lot of gas on exhaust Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 14, 2013 Share Posted August 14, 2013 If its showing two wet plugs and its still sparking on those plugs its almost certainly a couple of stuck open injectors. Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 14, 2013 Share Posted August 14, 2013 And which could be the reason that they are stuck open? And should i unmount and clean them or what can i do? Quote Link to comment Share on other sites More sharing options...
trebor69 Posted August 14, 2013 Share Posted August 14, 2013 Have you had your distributor out ? I have had mine out a few times and if not put back exactly right (1 tooth out) then it sounds like yours .....just a thought. Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 15, 2013 Share Posted August 15, 2013 No i didn`t touch anything. I was drivig with almost 80km/h when the check engine got on and after that misfired a few times and it does like in the video above. I didn`t touch anything. P.S Sometimes, before this problem, the check engine light got on and the car worked right and after a while (1 minute) the light turned off. I thought it was a sensor. Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 15, 2013 Share Posted August 15, 2013 Check your MAF sensor by the air filter box. It may be unplugged or broken, so the ECU is overfuelling and causing your problems. - - - Updated - - - Changed the thread title to something more meaningful Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 15, 2013 Share Posted August 15, 2013 Thanks for your advice i will check and for the title. Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 16, 2013 Share Posted August 16, 2013 Can anyone tell me which is the K line on the diagnose jack? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 16, 2013 Share Posted August 16, 2013 Cant remember if its OBD2, if it is its pin 7. Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted August 18, 2013 Share Posted August 18, 2013 This is my jack which one is pin 7 ? Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted September 1, 2013 Share Posted September 1, 2013 I changed the plugs, spark plugs and the air sensor from the air cleaner and now i think its ok, she runs in idle and no smoke. Still a little missfire appear once in a while. Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted September 2, 2013 Share Posted September 2, 2013 (edited) Now is not reving over 4k rpm and check engine turned on Why? Fuel pump or the wire between the MAP sensor and the ECU as i ve seen on other threat? Edited September 2, 2013 by jvanovich (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted October 9, 2014 Share Posted October 9, 2014 (edited) It's a lot time that appear this yellow light , while i'm running with the car after some chilometer appear this yellow light but is stopped together with the red stop signal in the odometer. the car goes like nothing is happened and if you try to go faster there are no problems. All seems ok. any bad changement in the car or strange noises from engine. I have to have afraid of it? COuld someone give an opinion for experience? the model is 93 NA with whifbitz exhaust and hks induction kit. NO SWAP no other changements at the moment. Could someone give me a link where to buy the connerctors? thanks in advance. Hi i had the same problem with mine. Now i have bigger problems but all started in the same way. After a while the engine started to missfire. I cleaned the injectors and it worked again for a while and missfired again i took the injectors out again and i fitted them back no cleaning no nothing and it worked for a while again.I didnt used the car for a year not even started for a year. These days i started the car the idle was 2000 RPM missfires and is very noisy. I didnt had the cable too. i changed some parts. I changed the air sensor, sparkplugs, spark distribuitor and today i changed those rubber rings fron the injectors. now the idle is at 1000 RPM still missfires and missfires are in the intake. I tried the TE1 with E1 Thing to get a code but nothing happened sorry for my english i am from Romania And sorry for posting in this threat. Edited October 9, 2014 by jvanovich (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest jvanovich Posted October 9, 2014 Share Posted October 9, 2014 Please HELP! Quote Link to comment Share on other sites More sharing options...
