Dynamat
millar11
It does help, when applied correctly, in the correct places. It's mainly to reduce vibration but also does reduce background noise.
I've got some different stuff in my GT-R at the moment that doesn't need to be heated and it's quite malleable.
I've always been interested in this too, but not really sure on exactly where to put it.
I mean, to make a noticeable difference, how mad do you need to go?
A noticeable difference you don't actually need a lot.
But you can go over board.
Best places to start, transmission tunnel, door cars, rear seat and boot. And doesn't have to cover every inch as it absorbs vibrations and sounds.
But you can cover every inch of metal and it would work a treat.
Flashing from B&Q is a really good substitute and is easier to place and mould.
You don't have to go mad at all. Iirc piece in the centre of a panel/area is enough. I think it's roughly a third (no more than half) the size of the square area that it is going on.
For example, (I know it isnt, but hey) if you did a door. Say it's 2 metres squared in area. A piece in the centre of the door 65cm squared, should be enough.
