Non Turbo Crank Pulley
Jamesc183
Thanks for the quick reply mate. Might be after a second hand one seeing as tho I nearly just had a heart attack. lol (£349.99)
Things as important as a crank pulley, I would always to advise buying new. You could buy one second hand, but that one could fail rather quickly.
If a crank pulley splits whilst driving on the motorway for example, it could bounce around a cause a lot of damage to the radiator and other things.
It's not worth the risk buying second hand in my opinion, unless it's a gauranteed very low mileage one, but even then, I'd be wary of it.
Whifbitz do a blueprint copy crank pulley. I have one on mine, and have had no problems. It's a bit cheaper than oem too.
Long breaker bar, and make sure the end of it is resting against the floor on the PASSENGER SIDE!!!!!!! Crank the engine over, and it should come loose. DO NOT LET THE ENGINE START!!!!!!
Thanks for the response guys!
Just to confirm is there anything I need to disconnect before turning the engine? Just wanna make sure i dont turn the damn engine on. lol
