fastcar Posted August 10, 2013 Share Posted August 10, 2013 Just wondering if anyone knew how much power the stock duel mass flywheel can take? I was always under the asumption that it could only take around 400-450BHP but after chatting to a well known member and trader on here they are saying maybe a bit more like around 600BHP. Has anyone ever pushed the duel mass this far and if so how long did it last? My plans with the supra is to have a max output of around 650BHP responsive drivable street car. I was origenly thinking of a multi plate clutch but the noise will do my nut in so I'm now thinking of a uprated single plate clutch and a stock duel mass flywheel Quote Link to comment Share on other sites More sharing options...
imi Posted August 10, 2013 Share Posted August 10, 2013 Mine runs fine with the stock dual mass flywheel. It's a brilliant setup. Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 11, 2013 Share Posted August 11, 2013 I would imagine its more of a torque limitation over a power one Also sidestepping the clutch is going to have a huge effect over normal driving, rolling start kind of things. Quote Link to comment Share on other sites More sharing options...
Lee P Posted August 11, 2013 Share Posted August 11, 2013 If its in good shape will take good power and torque. Ricky was running 700hp no problem Jamie p was running more than that for some time and lots of abuse As Tim says its the torque that's the issue but its fairly relative to power depending on turbo Quote Link to comment Share on other sites More sharing options...
Luxluc Posted August 11, 2013 Share Posted August 11, 2013 My multiplate clutch with flywheel is not noisy at all. The single clutch with lightened flywheel I was running before was noisy between 1.5 and 2.2k though. Quote Link to comment Share on other sites More sharing options...
fastcar Posted August 11, 2013 Author Share Posted August 11, 2013 Thanks a lot fellas that has helped me make up my mind for sure now. Looks like I will be putting a duel mass back in with an uprated single plate clutch hopefully that will make it more user friendly. Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 11, 2013 Share Posted August 11, 2013 exactly the same route i'm going for on a street single setup. Around 600bhp is my goal so sounds like were very similar. what clutch are you thinking of? i was going to use something like a spec stage 3+ as i use that on all my other cars and really like the feel/lightness of the unit. Tim Quote Link to comment Share on other sites More sharing options...
fastcar Posted August 11, 2013 Author Share Posted August 11, 2013 exactly the same route i'm going for on a street single setup. Around 600bhp is my goal so sounds like were very similar. what clutch are you thinking of? i was going to use something like a spec stage 3+ as i use that on all my other cars and really like the feel/lightness of the unit. Tim i Have been chatting with Jamsey AKA Do-Luck supra and he says Lee P has put a few in costumers cars with great results so I think im going to be going down that route. Not sure what stage im going to be going for yet but im sure it will be the spec clutch Quote Link to comment Share on other sites More sharing options...
TBDevelopments Posted August 11, 2013 Share Posted August 11, 2013 i've had good experiences with them. They did have a bit of a bad rep in america many years ago but i stopped using RPS and went to the Spec ones and never looked back. Tim Quote Link to comment Share on other sites More sharing options...
