Guest frostydriftyo Posted August 10, 2013 Share Posted August 10, 2013 I just bought a HKS QV3 with supra fitting kit but it will not fit, my car seems to be different to every other supra turbo I have seen. Does anybody know why mine is different? I have highlighted the difference in the pic, all other cars have a hose here which you just remove and replace with the hose supplied in the dump valve fitting kit but as you can see mine is metal :/ any help would be greatly appreciated Thanks Craig Link to comment Share on other sites More sharing options...
safcdixon Posted August 10, 2013 Share Posted August 10, 2013 Tbh the whole turbo side of your engine looks different to mine? Have you got anymore pics? Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted August 10, 2013 Share Posted August 10, 2013 this should be better Link to comment Share on other sites More sharing options...
DodgyRog Posted August 11, 2013 Share Posted August 11, 2013 I could be totally wrong, so hopefully someone with more knowledge on this will come along but it looks like the Turbo side (at least) is from the early GS300/Aristo Twin Turbo set up Link to comment Share on other sites More sharing options...
safcdixon Posted August 11, 2013 Share Posted August 11, 2013 I could be totally wrong, so hopefully someone with more knowledge on this will come along but it looks like the Turbo side (at least) is from the early GS300/Aristo Twin Turbo set up I think your right Rog it looks alot different to mine less pipes, different shaped pipes etc Is your supra originally an N/a? Check your vin plate to comfirm if its a gte or ge it may have had a transplant from another model Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted August 11, 2013 Share Posted August 11, 2013 Thanks I will do that now I forgot to mention that it is a j spec car, would that make any difference? Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted August 11, 2013 Share Posted August 11, 2013 I think your right Rog it looks alot different to mine less pipes, different shaped pipes etc Is your supra originally an N/a? Check your vin plate to comfirm if its a gte or ge it may have had a transplant from another model Yeah it's says 2jz gte on the vin plate. Strange :/ Link to comment Share on other sites More sharing options...
DodgyRog Posted August 11, 2013 Share Posted August 11, 2013 Yeah it's says 2jz gte on the vin plate. Strange :/ I guess someone changed the Turbos over and got an Aristo set so changed all the pipework as well Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted August 12, 2013 Share Posted August 12, 2013 O didn't know that lol any suggestions on how to fit the dump valve? I don't have a clue now Link to comment Share on other sites More sharing options...
Lee P Posted August 12, 2013 Share Posted August 12, 2013 Yep, its an aristo engine or turbo side Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted August 12, 2013 Share Posted August 12, 2013 What a joke lol still proper fast tho Link to comment Share on other sites More sharing options...
safcdixon Posted August 12, 2013 Share Posted August 12, 2013 You should still be able to fit the hks though there will be a quide on clubaristo take a mooch over there or change your thread title so the aristo guys on here see it, they will be able to help im sure Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted August 20, 2013 Share Posted August 20, 2013 Had no luck finding anything anybody got any other ideas Link to comment Share on other sites More sharing options...
Nic Posted August 20, 2013 Share Posted August 20, 2013 Had no luck finding anything anybody got any other ideas The Supra and Aristo use the same SSQV fittings. Can you post up a pic of the SSQV kit you have? Link to comment Share on other sites More sharing options...
2soops Posted August 20, 2013 Share Posted August 20, 2013 As people have said you seem to have the pipes from an Aristo or GS300, I ended up with a set the same when buying some from eBay for polishing. I believe they are the same as the Supra ones except for the front pipe that the bov attatches too. My solution would be to simply buy a Supra front pipe or set of pipes from someone on here and put the correct one on it. On a Supra one the bov is attatched with a rubber pipe at each end and not hard mounted to an aluminium flange. Should be an easy fix Link to comment Share on other sites More sharing options...
Philly_1 Lex Posted August 20, 2013 Share Posted August 20, 2013 If you got the full HKS SSQV fitting kit it comes with the part to attach the BOV to the aristo or the Supra fitting pipes. Also what 2soops is saying is correct about the differences in pipes. Link to comment Share on other sites More sharing options...
Guest frostydriftyo Posted September 5, 2013 Share Posted September 5, 2013 Thanks everybody for the help sorry i haven't said so sooner i couldn't log in with my phone :/ I sorted it for now by mounting it through the stock bov. Does anybody know of any reason not to do it tis way? Link to comment Share on other sites More sharing options...
