Window Motor
Patrick_Devlin
Guys,
Ive posted something on the For Sale, Wanted section.
I need a window motor. Mines just packed up. It's chewed the cable up and now the window is stuck down.
Can I just replace the cable?
Can I get the window up?
Has anyone got one lying around?
Are they unique to the Supra (can I fit another one?)
Help would be gratefully appreciated.
I had this very recently too....must be the colour they must have put duff ones in!
You haven't specified Drivers or passengers side.
Brian Duff has a passenger one for sale.
I had the drivers one off his scrapper! :D :p
EDIT - you need the whole mechanism not just the motor and cable.
A single strand of wire frayed on mine at the joining block on the mechanism....over a no. of months it tore up the pulley...the noise was like a crackling sound. Should have taken a look earlier :rolleyes: but I didn't.
There isn't much room inside the motor/pulley area and so if the cable goes, inside that area, then it could jam it straight away...
my drivers side cable was making noises then stopped working, stripped it down and cable had snapped
thought you might be able to buy new cable but its an all in one unit
cost me £70 dont know if it was including or excluding
i asked them how much to fit it, they wanted £92
as it was stripped i fitted it myself
easy job to do and i am crap
just take your time doing it
have fun
All fixed now,
Thanks to Nathan at TDi for sorting me out a 2nd hand part. 24 hour delivery and a couple of hours to fit it and I 've got a working window.
The top pulley had broken and the cable had tangled in the motor as a result. Bit of a bitch to remove the old one cos the window was stuck down.
Got the old one if anyone wants to recondition it?
Pat
I got the whole fixture for £130.
It included the motor, guide rail and window mount; the whole shooting match.
I havent taken the motor apart yet, but may do. The cable is frayed and I guess it could be mashed up inside the casing. The top runner (plastic) has broken also - the initial problem I think.
Pat
The motor will be fine if a little tired! Its the big pulley which will have lots of sharpe debris from the cable littering the inside. If you do open up the big pulley take care...I was picking fine bits of wire out of my fingers for the rest of the day. :looney:
Pat
£130 was that new?
when i did mine new part was £70about remember because toyota wanted more to fit it than the part was worth
its the cable in the round plastic plug that pulls both ways and has a slider bar . i thought it might have been more knowing toyota
Originally posted by MONKEYmark
£130 was that new?
Here is a picture of the entire assembly. This is what Toyota wanted to charge me £250 for...
It was the pulley on the left hand side behind the window bracket that broke.
