Noz Posted August 9, 2013 Share Posted August 9, 2013 Why do we not use them on our manuals? I think its the UK spec supra that had a diff cooler. I could be wrong there. But either way, for more power people use transmission coolers, though it's a weaker box has anyone tried this? Only reason I ask if my box is fine for the moment, and I want to keep it that way. If cooling a box can increase its limits then it may be cheaper than replacing it when it fails (prevention vs cure). Just an idea as I've never seen it done (or anyone discuss or compare a technical knowledge of why not to). Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 9, 2013 Share Posted August 9, 2013 I think its because they don't have a pump. im pretty sure wed need external pumps .. the autos have internal pumps to keep the pressure up and the fluid flowing Link to comment Share on other sites More sharing options...
Kirk Posted August 9, 2013 Share Posted August 9, 2013 You've never seen it done before because it can't be done without a complete redesign of the box. It's as simple as that. Link to comment Share on other sites More sharing options...
David P Posted August 9, 2013 Share Posted August 9, 2013 (edited) Drill and tap 2 holes or simply use the fill and drain to plumb in a pump and cooler. If you want one..... http://www.mkivsupra.net/vbb/showthread.php?236648-Gear-oil-pump-and-non-return-valve Edited August 9, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
Shane Posted August 9, 2013 Share Posted August 9, 2013 (edited) You've never seen it done before because it can't be done without a complete redesign of the box. It's as simple as that. On a Supra maybe, but other cars have it. TD5 Disco springs to mind. http://www.ebay.co.uk/itm/Lotus-Elise-Exige-S2-gearbox-gear-box-oil-cooler-kit-/290600562474?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43a924af2a Edited August 9, 2013 by Shane (see edit history) Link to comment Share on other sites More sharing options...
Pulley Posted August 9, 2013 Share Posted August 9, 2013 like david says, use fill and drain points and a pump (i bought my pump and cooler from merlin motorsport) and hey presto gearbox cooler same for diff simples Link to comment Share on other sites More sharing options...
Tsia Posted August 9, 2013 Share Posted August 9, 2013 But the question is, will it extend the life of the W58, or would it be money better spent on buying a non-fragile box? (Same situation myself!) Link to comment Share on other sites More sharing options...
Pulley Posted August 9, 2013 Share Posted August 9, 2013 it will help, the oil will benefit from being kept within its optimum operating temps, i usually run a cooler pump ,electric thermo switch and little fan on a radiator on my gearboxes and diffs, especially if im doing track tho the torque and power delivery of a single turbo on the w58 is harsh, so its just a matter of time really unless your very lucky Link to comment Share on other sites More sharing options...
Tsia Posted August 9, 2013 Share Posted August 9, 2013 NA-TT here (very) soon, so hopefully it'll let it last a little bit longer Link to comment Share on other sites More sharing options...
TRD-1 Posted August 9, 2013 Share Posted August 9, 2013 I think the Toyota Celica GT4 uses a gearbox oil cooler, Im pretty sure they all came with manual transmission to, so it would definitely be a option to try and prolong the life of the W58 at higher power levels. Link to comment Share on other sites More sharing options...
Kirk Posted August 10, 2013 Share Posted August 10, 2013 On a Supra maybe, but other cars have it. TD5 Disco springs to mind. I know that, I was referring to the Supra. Link to comment Share on other sites More sharing options...
Noz Posted August 11, 2013 Author Share Posted August 11, 2013 Considering mine has lasted so long, I think I've got a good one. For that reason, I just thought I'd explore the options for low cost. R154 is £1k if your lucky, IF. I wouldn't spend a lot on a setup, it's just something that I thought of. I think it's worth doing, and when I change ECU's I'll look at doing it so I can creep up more power. If I try and fail, the results will speak for themselves. Link to comment Share on other sites More sharing options...
dr_jekyll Posted August 11, 2013 Share Posted August 11, 2013 when an idea grows it has to be tested Link to comment Share on other sites More sharing options...
Rich.2211 Posted August 11, 2013 Share Posted August 11, 2013 What I don't understand is how all these people on Supraforums seem to be pushing 400 horse power to the rear wheels through them okay. My only thoughts are that their idea of 400rwhp is a little different to ours. For the same setups their RWHP figures seem to be on a par with our FWHP figures, either they have forgot about transmission/drivetrain losses or dyno's read a good 10-15% higher over there. Link to comment Share on other sites More sharing options...
Noz Posted August 11, 2013 Author Share Posted August 11, 2013 probably using USA gearbox oil? Link to comment Share on other sites More sharing options...
