Guest ash125106 Posted August 9, 2013 Share Posted August 9, 2013 (edited) Hi Guys, I've recently brought a 1995 JDM Import Toyota Supra RZ, I wanted to know if it is possible and also how easy it is to upgrade the turbos from the ceramic, to install ones used in the Export Spec, as eventually I wanted to run higher boost pressure? Also if was to do this would I be able to get rid of the restrictor ring? Would this also replace the wastegate? Thanks Edited August 9, 2013 by ash125106 (see edit history) Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 9, 2013 Share Posted August 9, 2013 First time I've ever heard anyone wanting still turbos. Have a search, this has been covered many times Link to comment Share on other sites More sharing options...
listy Posted August 9, 2013 Share Posted August 9, 2013 A few companies do a hybrid conversion, which replaces the ceramic innards of the turbo with steel components. CR Turbos (I think its called) is one of them. To install UK Spec turbos (which already have steel internals) iirc you need to change the manifold also, as they are a different bolt pattern (I think). I'm sure someone will be along shortly to confirm/dispell what I've said. Link to comment Share on other sites More sharing options...
supra_aero Posted August 9, 2013 Share Posted August 9, 2013 First time I've ever heard anyone wanting still turbos. You are funny. lol Link to comment Share on other sites More sharing options...
tony tt Posted August 9, 2013 Share Posted August 9, 2013 Steel uk spec turbos will run slightly higher boost but will generate more heat. A good bpu set up on ceramic turbos is just as good. 1.2 bar on ceramics and 1.4bar on steel there isn't a lot of difference. If you click the bpu which should be in blue here if it links it from iPhone it will tell you everything you need to know about modifying the stock twins to maximum potential. Good luck and welcome to the forum. http://www.mkivsupra.net/vbb/showthread.php?94705-BPU-(Basic-Performance-Upgrade) Link to comment Share on other sites More sharing options...
supra joe Posted August 9, 2013 Share Posted August 9, 2013 First time I've ever heard anyone wanting still turbos. Maybe he just wants an N/A. Link to comment Share on other sites More sharing options...
tony tt Posted August 9, 2013 Share Posted August 9, 2013 First time I've ever heard anyone wanting still turbos. Maybe he just wants an N/A. Haha Link to comment Share on other sites More sharing options...
Nic Posted August 9, 2013 Share Posted August 9, 2013 (edited) Both turbos produce around the same power at the same boost pressure, the export spec turbos are smaller and slower to spool in comparison to the j-spec turbos, I definitely wouldn't call it an 'upgrade'. The sequential system is quite restrictive, anything above 1.2bar with either type of the turbo and the intake temps start to ramp up and any gains in power start to diminish. The fitting of the turbos is also different, they are not a straight swap, you'd also need to swap the manifold, turbo outlet and first decat pipe over. Edited August 9, 2013 by Nic (see edit history) Link to comment Share on other sites More sharing options...
supra_aero Posted August 9, 2013 Share Posted August 9, 2013 Sounds like its not worth the money. And from what I hear people who have been in uk and jap bpu's, the japs accelerate quicker. Which to me at least is what matters most. Link to comment Share on other sites More sharing options...
tony tt Posted August 9, 2013 Share Posted August 9, 2013 Sounds like its not worth the money. And from what I hear people who have been in uk and jap bpu's, the japs accelerate quicker. Which to me at least is what matters most. Yup Link to comment Share on other sites More sharing options...
DaveR Posted August 9, 2013 Share Posted August 9, 2013 Sounds like its not worth the money. And from what I hear people who have been in uk and jap bpu's, the japs accelerate quicker. Which to me at least is what matters most. Link to comment Share on other sites More sharing options...
