Question on Color Code on Front OEM Springs
Guest FLZ_Boy
Guest FLZ_Boy
I'm researching JDM Supras OEM spring color codes. Are the front spring color code dots both the same? In particular, do the factory Bilstein use the same color dot code for the front driver and passenger spring?
Guest FLZ_Boy
It determines proper stock ride height of the Supra. USDM Supras have different color codes to determine if the front spring belongs on the driver side or passenger. I received a 96 SZR complete suspension (Bilstein and Springs)I notice the front springs had the same color code. I'm curious now if JDM Supras needed different springs. Right now my USDM Supra has uneven ride height with the 96 SZR suspension. I figured JDM Supras didn't have different color code springs since the driver weight would balance out the ride height. Whereas, the USDM driver side would only compound the ride height on the driver side to be even lower.
Just had a look at the EPC, the US spec Supra has a different part number for the left and right front springs, the rears are the same part number each side.
The J-spec and UK spec Supra use the same spring part number left and right.
Guest FLZ_Boy
I'm glad Toyota thought way in advance back in the 90's that the average American would become obese by the turn of the century. :thumbs:
However, irregardless of driver weight, now I just need to swap out the passenger side to the USDM passenger side spring to bring her back to the correct ride height for a LHD.
Well don't us owners always say that Toyota seriously over engineered the car so we can still be competitive 20 years later :D
Guest FLZ_Boy
Actually, there is a good finger difference in the gap between the driver and passenger side. As for spring rate difference, you are correct the variance is small.
