Mike_Mac Posted August 6, 2013 Share Posted August 6, 2013 (edited) Since my supra's been back on the road (stripped/cleaned/renewed both turbo and intake sides of the engine) I've started to notice a 'whooshing' sound when I lift off when #1's spooling. I've tried to get it on video here: http://youtu.be/ScwKyNQfH7U http://youtu.be/EENZSxCToQY http://youtu.be/klabvEP3V7Y To me it sounds like compressor surge at times (I think), so I'm concerned it may be the BOV and that if it is it's damaging the turbos. Can anyone confirm what this could be? Edited August 6, 2013 by Mike_Mac (see edit history) Link to comment Share on other sites More sharing options...
Pete Posted August 6, 2013 Share Posted August 6, 2013 Some people pay good money to have noises like that. Link to comment Share on other sites More sharing options...
Mike_Mac Posted August 6, 2013 Author Share Posted August 6, 2013 (edited) Some people pay good money to have noises like that. I know, but I also know that that noise is usually surge and, while sounding 'cool', isn't good for the turbos. Plus I'm not even sure that's what it is and how concerned I should be about it! Edited August 6, 2013 by Mike_Mac (see edit history) Link to comment Share on other sites More sharing options...
Rich.2211 Posted August 6, 2013 Share Posted August 6, 2013 If it's of any help mine used to sound the same with a HKS SSQV. First turbo, light throttle and back off and I got that noise over and over again. Link to comment Share on other sites More sharing options...
Mike_Mac Posted August 6, 2013 Author Share Posted August 6, 2013 If it's of any help mine used to sound the same with a HKS SSQV. First turbo, light throttle and back off and I got that noise over and over again. Thanks for that. Link to comment Share on other sites More sharing options...
Nic Posted August 6, 2013 Share Posted August 6, 2013 Sounds normal to me, what BOV is fitted? Do you have an aftermarket induction kit fitted? Link to comment Share on other sites More sharing options...
safcdixon Posted August 6, 2013 Share Posted August 6, 2013 Mines the same mate, id describe it as chatter though thats what we used to call it when i was a ford fella Hks ssqv with purple insert on mine btw Link to comment Share on other sites More sharing options...
Mike_Mac Posted August 6, 2013 Author Share Posted August 6, 2013 Stock BOV on mine - currently not even BPU. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2013 Share Posted August 8, 2013 But not a stock air filter box? Link to comment Share on other sites More sharing options...
Mike_Mac Posted August 8, 2013 Author Share Posted August 8, 2013 But not a stock air filter box? Yes - its on the stock air-box too. Literally nothing engine-wise has been altered and the cats are currently on, as well as the correct grade plugs. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2013 Share Posted August 8, 2013 Dunno then, a stock BOV and air box is designed to mask turbo stall. I'd turn the radio up and wait for something to happen to make diagnosis easier myself Link to comment Share on other sites More sharing options...
Mike_Mac Posted August 8, 2013 Author Share Posted August 8, 2013 Not sure if that would be a good idea Chris . Is it possible the BOV is knackered? I have just had everything off that side, replaced all the hoses and painted the metal-work. Might have given it a knock while it was off or something similar? Link to comment Share on other sites More sharing options...
Guigsy Posted August 8, 2013 Share Posted August 8, 2013 Dunno then, a stock BOV and air box is designed to mask turbo stall. I'd turn the radio up and wait for something to happen to make diagnosis easier myself If it ain't broke. Break it then fix it Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 8, 2013 Share Posted August 8, 2013 (edited) If the BOV was stuck open you'd make very poor boost at lower throttle openings. If it was stuck CLOSED you may get some noise from turbo stall. I never run a BOV on any turbo engine that I build or modify, they are solely to stop noise. There's a slim chance it's not opening with vacuum applied to the small port. You'd need a vacuum pump to test it, or you could perhaps remove it, feed it a vac source from the head side of the throttle body, snap the throttle open to about 5000 RPM, then closed and see if it allows you to blow through one of the bigger ports for a second. IE, use the engine itself as a vac test source. It could also be that for some reason vacuum isn't available at the small port due to a crimped pipe or a pipe blockage. Edited August 8, 2013 by Chris Wilson (see edit history) Link to comment Share on other sites More sharing options...
Guigsy Posted August 8, 2013 Share Posted August 8, 2013 I don't run a bov on my single. But that's mainly FOR the noise Link to comment Share on other sites More sharing options...
