extending lambda wire
berg
Just finished my NA-T build but i need to extend one of the o2 sensor wires so it reaches the new downpipe
I have the single wire o2 sensors which have one single silver strand covered by lots of copper looking wire.
Can anyone poiunt me in the right direction to which wire i can use to extend this as im guessing normal wire will be no good as it looks different
Cheers
To get you out a hole, even use two smaller wires to get the same amount of wire for them. Only do this if your 100% in a hole.
Make sure you tie the new wire out the way or the solder will re-melt on the downpipe and break off, I've seen it happen.
