Relocation of items for FMIC fitting
ronttuk
Where do you re locate the expansion bottle or is there a smaller alternative?
Also where do you mount the active spoiler motor when FMIC is fitted ?
Sometimes you wish you just left things alone !!
think you can get an expansion tank off whifbits that fits nicely between the battery and headlight. have a look
  • 4 weeks later...
I just moved the stock one, used the factory bracket as well - it took 2 minutes and cost me one M6 bolt, two washers and a Nyloc nut. Bargain! It sits pretty much stock location just a little further down and a little further back (I have deleted air con radiator though which thinking about it is why more people probably don't do it this way).
Thanks TYSON I found it,now the red triangle has gone out but theres always a but the airbag warning light has come on grrrrr and the ariel wont retract I guess I missed a plug out behind the dash so when i get a chance the dash has got to come out again !!!
No problem :)
I did so I guess its unplug the battery to reset it
no that work im afraid, you need to make a link up and goto diagnostic port and touch one terminal while intermittentley touching the error code, there is a link to do this and its a right pita, or goto toyota and clear that way
